Electric Horn Location?
Jonathan M
Connecticut
Well I bought a 1983 AM General M923. Against all advice I am attempting to get it to pass inspection so I can use it for things other than parades and the such and not have to worry about the long arm of the law. A mechanic tells me I must have a functional city (electric) horn, among many other things. My working air horn is not going to get me through inspection. OK, so I bought a 24 volt military horn and dash button. Now the question is where should I mount it? As far as I know the truck never had one. I was thinking of mounting it to the frame tucked in under the radiator on the passenger side but only because I don't know any better. I searched the internet for pictures of an electric horn mounted on a similar truck but came up with nothing. Is there a proper location for an electric horn on the M939 series?
Picture of the horn I bought at this link.... https://sep.yimg.com/ay/yhst-33652407708730/24-volt-horn-for-military-vehicles-m151-m715-etc-10.jpg
74M35A2
317
Livonia, MI
Welcome and congrats. Real trucks have air horns (looking at your sig line). Not sure your mechanic is correct, air horn should also suffice?
1,174
Since you are trying to satisfy your mechanic, I'd ask him where to place the horn and switch.
I think he's wrong.
CMPPhil
376
Temple, NH
Hi
Push a tennis ball into the trumpet of your air horn, makes a good mute for a short toot. Very pleasant sound. If a more definitive warning is needed just hold the horn for a long blast. After a moment there will be a pop as the tennis ball is fired as a visual warning along with loud blast of the horn.
If you have twin air horns mounted on the cab roof I suggest one green and one orange tennis ball.
If you wonder how this was discovered? Was testing air horns in the shop, loud, so grabbed two balls and them stuffed in the horns. First toot, nice. Long blast bounced of the balls off the shop door.
But back to your original question, did the mechanic check for a backup warning horn? I would suggest a location down near the bumper out side the engine compartment, the horn has to be louder than than background noise of the truck.
Cheers Phil
73m819
319
gainesville, ga.
Yes most states require electric horns, the rationale behind this is that air may go away so no warning horn where a electric horn only needs a electric source to be active, I know this is not very realistic being that if air goes away, the truck is not going anywhere so a warning horn is not needed, BUT who ever said that bureaucrats were realistic.
Gunzy
66
Roy, Utah
Mount it right behind the grill. I have a HEMTT that has both air and electric horns from the factory and the electric one is just behind the grill.
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Mount it to the flat spot under your hood just below the headlight. This is between the bumper and hood in that little gap. Nice little wide spot and it is there so atleast sound can get out. paint in green and noone will notice it.
