springer1981
- 1,149
- 93
- Maine
Thanks, I'm not using it for a turret but I am using the joystick for rear steering and now that I have looked at it more I'm going to require more than the 3 wires in the cable. I'll probably end up changing out the connector for 5 or more wires. If they are hard to find it should go to someone using it for its intended purpose.I might have a spare.
You will have to find a different joy stick as the turret one is only a 3 wire J/S.Thanks, I'm not using it for a turret but I am using the joystick for rear steering and now that I have looked at it more I'm going to require more than the 3 wires in the cable. I'll probably end up changing out the connector for 5 or more wires. If they are hard to find it should go to someone using it for its intended purpose.
Thanks for the info. I think I can make it work one way or another. If you would like to see where I'm at with the joystick you can check out my project here https://www.steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2420108 This is where I dissect a joystick to see how it works and what I can do to modify it.You will have to find a different joy stick as the turret one is only a 3 wire J/S.
Hi, I just saw this post from last year. Do you have a joystick cable for sale ? If yes, How much ?Thanks for the info. I think I can make it work one way or another. If you would like to see where I'm at with the joystick you can check out my project here https://www.steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2420108 This is where I dissect a joystick to see how it works and what I can do to modify it.
Hi, I just saw this post from last year. Do you have a joystick cable for sale ? If yes, How much ?You will have to find a different joy stick as the turret one is only a 3 wire J/S.
Thanks !!! Im also trying to find the cable that goes from the BPMTU to the battery pack ( big female connector (2 pins).I'll check
Thanks for the reply. Yes I saw some on ebay. But the price is too high Im trying to find here with the communityThey are on eBay…
both for 200 ?I have 2 ea. Joy stick wires...one has jb weld on connector.
$ 100 for repaired one.
$150 for other one. .
Plus shipping
