electric winch for deuce
avengeusa
MI USA
some people have, I have heard that before, should not be a hard thing to accomplish, just need power and fab some mounts up
1,176
Scroll to the bottom of this thread! There are a few threads listed in the Similar Threads.
I have a 2" receiver hitch mounted 10000lb winch. I use it on an old hitch that I occasionally mount "upside down" on the front of the deuce bed. I use it to pull stuff onto my trailer or up into the bed.
shannondeese
High Springs Fl
I am working with Mile Marker to produce a 18,500 lb 24 volt electric winch that will mount in the deuce behind the stock bumper. I am not sure when it will be ready for production but once it is I'll post it.
x-ray
Brockport, NY
I mounted a cheap 12V electric winch to the bed to haul loads up omto the bed. It comes in handy.
Wired it to one battery and ground
An electric winch probably won't get your deuce out of trouble, but to use it for hauling loads onto the bed of a deuce, its priceless in my opinion.
tm america
24
merrillville in
it can and has been done but i havent seen any electric winches with the same line pull rating as the stock deuce winch and you need snatch blocks even with the stock winch.the deuce winch has a 10000lbs line pull and a 10000lb electric winch will have a line pull rating around 4000-5000 thats why they dont have as big of a cable .if you have an electric winch with a 95 ft cable and have to run three snatch blocks to get the pull you need you will only have a reach of about 19ft and wont be much good for getting you out of the mudd:roll:
