Electrical question
jasonjc
283
Gravette Ar.
The 100 amp voltage regulator would depend on the gen/altator you have my has a 60 amp with a built in regulator and thus the extrunal would not work.
as for the blinkers sounds like a short or a bad light switch
jason
Red Neck
CT
Just a thought, when the volatge drops low, sometimes electrical components won't function correctly. This would be the case if the flasher was a civilian type, but I am not sure on the electronic mil type. Anyway, fix the charging system before you worry too much on other items.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
When you fix the regulator, you should be good on the turn signals. My turn signals don't blink if the battery is low, the lite stays solid.
Dennis
________
British cooking
