Electrical saga
92'M998
Bullard, TX
Hi -
As things go on - mechanic checked the circuit breakers, no prob. PCB is not putting out. Batteries charged, load tested, nothing when the key is turned. The key ignition switch is good. Is there a specific model for a 92 M 998? The box is painted over, so i will get a better idea of type after scrapping the paint to see the label. The goal is tho get the motor started so we can check the generator to see why the overload. Any suggestions? Thanks. J
