Electricity
mutt_r
31
Lower Saxony, Germany
First I am not a guru in a vehicle's electricity. But I have a problem with my Goat where some help or a good advice might be very helpful.
This is the situation:
When I am on the brake pedal or setting the turn signal to the right, the bulb on the carrier's right hand (driver's side) is not working. It is just dark. With a multimeter I can measure just 16.7V instead of over 24V. Perhaps a cable going against ground? The turn light in front of the Goat is working fine.
I continued checking all cables from the inter-vehicular connector between the tractor and the carrier's rear lamps thinking of a ground problem. But all cables are okay.
So I opened the tractor's dash panel to see if there is something causing the problem.
Well, cable #37 has been cut by someone. From the wiring diagram this cable should go thru the whole harness and will end at the trailer connector (marked as "Aux Power"). For what was this used? A special trailer behind the Goat's carrier?
Next thing I am wondering: The bulb for high beam in the instrument cluster is "on" while head light is on. But I have not pushed the high beam button. When I push the high beam button, this high beam indicator is becoming much more brighter. I do not know this from my M151, so I think something might be wrong, too.
Is it possible that the light switch is causing my headache?
Your turn ...
dmetalmiki
2,027
London England
That does sound like an earthing problem. (grounding). I alleays use a "hot" wire straight from a battery positive (+) and with the sharp probe at the other end poke the wiers at various points (enroute) to see if light come up bright, or it that lamp goes out on low beam. Same goes for earthing at various points. >in the EARTH circuit (only).
So, good clean positive supplies. And good clean earthing points.
