Electronic Parts Replacements Info for the MEP-802A
Guyfang
27,237
Burgkunstadt, Germany
....and I realize I should have disconnected the battery terminals prior to sticking a metal wrench inside the cabinet.
Not quite right. You realize NOW, that you should have disconnected the Negative Battery Terminal before sticking a wrench in there.
Learning by doing.
😁 A lesson you will not forget soon.
Thumpin
Melbourne, Kentucky
Thank you all for your help. I just watched a video on what an MOV is and it helped a lot. It is likely that I may not have hurt anything when I made contact. I do believe the 7.5 amp circuit breaker tripped.....and it is likely that I may have touched the resistor above and not the V5 terminal.
I looked at the circuit and I could not tell where the wire goes after leaving the V5 varistor. I could only tell that it goes to Circuit Board 5 - terminal 10....but then I could not find anymore information on the cabinet that tells me where that is or what it does.
Hopefully I can get the generator fired up and connected to a significant load this week and see if everything works as it should.
Dave
Thumpin
Melbourne, Kentucky
I just wanted to follow up and give you all an update.
I got all the repairs finished, fired it up, and connected it to my RV with the AC and two 1,500 watt heaters.
The MEP802A ran just fine at a 60% load for half an hour. There was a bit of a smell from it as it warmed up and burnt off the stale smell from 20 years of being in storage - but it performed flawlessly!
Thankfully my clumsy wrench incident didn't do any damage!
kloppk
4,198
Massachusetts
You ought to start your own thread regarding your starting issues.
That way it will get the visibility needed to address your 802's starting issues.
When you do, indicate if the 802 is new to you, if it has started properly for you in the past and another other historical info.
Top covers available here in the Classifieds ---> 802 parts
Forum etiquette is to relegate working on a generator to a single thread that you've started. Don't post up the same question in multiple threads as it makes it hard for us to efficiently help you. We're here to help :)
