Emergency shutdown
timntrucks
146
Ponchatoula LA
its the same as on a m818. i have a spare cable but that setup didnt come with a return spring. its a one time emergency shut off. so if you use it you will have to raise your hood and manually reset it. TIm
m139h2otruck
NH
Try Saturn Supply. Might have to call and talk to someone to get the right cable, as the list on the site only shows NSA numbers.
Lorax
Hampton Virginia
You pull the handle on the dash out, the cable then pulls on a lever on top of the fuel solenoid above the injector pump. When starting the truck, then solenoid gets energized and opens to allow fuel to the pump. When shutting down, then solenoid de-energizes, cutting the fuel off to the pump. All the emergency handle does is over ride the solenoid and manually shuts the fuel down. Pulling the handle is a one time use thing, so if you want to start up again, you have to push the lever back by hand. Pushing in the emergency handle won't reset it.
