End of my rope!
spicergear
29
Millerstown, PA
You can also get a small electric fuel pump and hook it into the vent line on the MC. Turn it on and let if perk along building up it's small, like 5psi, in the brake lines. Make sure your reservoir is large enough that you don't run the pump dry. You need just one soldier then and can put a clear tube on the bleeder and watch the fluid pour into a container. Make sure you're also following the correct wheel order to bleed or you will leave air somewhere. Running this small pump won't agitate the fluid too much.
