choll
- 5
- 18
- Las Vegas,NV
Moving to the Chicago area, I hear it gets pretty cold in the winter. Anyone have any suggestions for a block heater?
where im from we get about 2-3 weeks when it hit 65 below zero...Good glow plugs are a must! Even without a block heater here in north chicago, changed out the glow plugs and never had an issue the past 2 winters. Took it forever to warm up though, heard the block heater helps with that tooGet block heater and make sure glow plugs are good and working and will start fine! I plug mine in about 1/2 hour and cycle glow plugs and always starts![]()
I found the following part numbers for the heaters: ZeroStart #3100057 (600 Watt) or 3100059 (1000 Watt).I've got a ZeroStart block heater from NAPA, it was about $30 and works great here in upstate NY. Plug in for about two hours even in sub-zero and starts right up. I installed it in the middle freeze plug of the drivers side, and the cord is the perfect length to run out the grill behind the bridge plate.
