Engine for 1984 m1008
hwcurtice
35
Moncks Corner, SC
First, I need to verify what engine actually came with the truck.
Second, How difficult is it to find a running one? Engine, that it. Truck I'm looking at threw a rod. Seller claims 6.2L
Third, What does a running engine go for these days?
Geesh You guys, Cut the man some slack :]
Mine came with a briggs and stratton, thats factory right?:twisted:
A running 6.2,Here In NC Goes for anywheres from $600 on up Running. The Civiy 6.2 is the Cheapest around Here.If you want a j code 6.2 Then probably $1000 and Up Complete with Brackets and everything to drop in.
As for The Briggs and Stratton Thats a a well sought after option, Man you have a gold mine :] The M1008 thats got that is one Awesome Ride.
hwcurtice
35
Moncks Corner, SC
Thanks for all your useful (CHOKE) advise. I asked this one the fly therefore, didn't use the search, nor did I even see the sticky.
I did think that these came stock with 16 inch tires, to match the m101a2 trailers, but I see I was incorrect.
So I learned something new today. Maybe a couple things....
hwcurtice
35
Moncks Corner, SC
hmmmm that's odd, The sticky says 15" and the truck I'm looking at has 15".
And I don't see and engines in the classified section.
Off to CL, I guess or maybe eBay.
Warthog
232
OKC, OK
I fixed the Wiki. The M1009 tire was listed but not the others. Thanks for pointing that out.
Are the axles on the truck you are looking at 8 bolt hubs or 6 bolt? I don't think I have ever seen a 15" 8 bolt rim
original
Pineville, West Virginia
I've got a good 6.2 in the truck running now, but I don't think that will help you were to far apart. You can send me a message if your interested, I will give you a good price based on the shipping you would have to pay. Good luck, mate.
11Echo
92
CT W. R.
Aftermarket used to have 15" eight lug wheels available.
I bought a great parts vehicle that had a set on it with 33/12.50-15 BFG's mounted.
