Engine governor
V8Astro
StL/MO
What limits the engine RPM on an '08? On a downshift my engine RPM has pegged the tach past 4k. Kinda makes me worry...
Warthog
232
OKC, OK
The throttle pedal is the only governor. Or when the engine comes apart...:p
1,178
Do you manually downshift?
Keith_J
1,323
Schertz TX
Injection pump adjustment. When you mash on the go pedal with your right foot, you are compressing a coil spring which increases the force the spring can exert on the other side of the control system, the centrifugal force (centripetal acceleration X mass) opposes the spring force.
The system is designed with considerable droop, that is the drop in engine RPM with increasing load. This prevents hunting, the instability of engine control.
With the droop comes the ability to exceed the speed ceiling. It is all a bunch of partial differential equations which is beyond the scope of this thread :shock:. Plus I'm on beer #3.
My recommendation? Check your throttle vacuum regulator and transmission modulator/governor. It is highly unlikely there is an issue with the injection pump governor.
1,178
FWIW, it is easy to over speed(exceed governor limit) with kinetic energy. No droop.
trukhead
dane/wi
I wish I'da learned some differential equations, I have a calc book and the solutions manual, maybe I will for giggles.:cool:
I've banned members or PUI.:beer:
What's PUI?:whistle:
o1951
155
Bergen County, NJ
9 beers later and PUI is still a mystery!:whistle:
However, now would be a good time to anwer the original question in easy terms. Engine has a governor, which can control fuel. Properly set, it protects engine from overspeed only when controlling fuel can stop speed increase.
It CANNOT protect the engine from overspeed when the load is powering it! Even shutting off all fuel cannot stop it.
Example -vehicle is going 50 MPH down a grade (80 KPH). OP manages to shift into first gear, which would be a gadzillion engine revs at 50 MPH. As long as drivetrain holds together, engine is forced to overspeed to destruction.
That is kinda what doghead said in post #8.
Posting Under the Influence=PUI hahaha :grd:I have to say this thread was hillarious and the governor i beleive its your foot.I personally dont run my m1008 over 55mph its already kinda screaming.
And i have been told i didnt have a sense of humor.:]
1,178
Yes indeed, PUI is posting under the influence.
We do not need drunken(or whatever your on) senseless ramblings posted on the site.
This can and will be followed with a loss of posting privileges, banning or worse! :shock:
Skinny
488
Portsmouth, NH
This is what happens when young kids can't figure out a standard H shift pattern on a six speed transmission. Why does the scan tool show a cam and crank correlation issue at 13,000 rpms??? DOH! Don't let off the clutch pedal unless you know what gear you're in :)
o1951
155
Bergen County, NJ
:funny:
:jumpin:ROFL says the old timer who has double clutch shifted 17 speed tractors
