Engine Oil Cooler Pipes
cjkeeliii
Thomasville, GA
Does anyone know who sells the engine oil cooler pipes? These are the aluminum pipes that travel behind the radiator. I've been on-line and to several parts houses and can't find any references. Thanks.
doghead
4 Star General /Moderator
1,193
NY
There are several threads covering this.
I did a search for "oil cooler lines" in the CUCV forum.
Found all this, Steel Soldiers::Military Vehicles Supersite - Search Results
I know there are NAPA numbers and Dorman numbers listed in some of those threads. The napa lines ARE Dorman parts. None of them fix exactly.
If I had to do it again, I might have full length rubber lines made .
Edit! after reading your post again, I see you are looking for the front, all aluminum lines. I don't know if they are available or where to get them. Maybe they are covered in the posts from my search results?
The part numbers from the -20TM may be GM part numbers.
doghead
1,193
NY
No need to be sorry.
If you don't find your answer in those search results, we'll find what you need somewhere!
BIG_RED
Winnipeg, Manitoba
Worst case scenario, I'd use an Aux. oil cooler infront of the rad with some modification to the lines. I've seen them on sale for like $50 with some generic lines. Good Luck!
