- 2,088
- 621
- 113
- Orlando, FL
Has anybody found engine oil used in the TH400 transmission of their CUCV instead of Dexron? I know they use engine oil in some of the big truck automatics but I didn't expect to find it in a CUCV.
Can't agree with the post directly above.
15w-40 is listed as an extreme duty lube for automatics.
( Edit, Too slow,a post in between. )
(second edit) 15w-40 needs a significant warm up time before use in cold weather
Allow me to play Captain Obvious here for a moment. Whatever is in that trans could always be drained out along with 2 or 3 flushes worth of ATF, cut with a little gasoline or a little more #2 diesel and run it in your M818 if it's a Multifuel. If you don't have a Multifuel in that beast, there's plenty of Multifuel owners here and there that'll be happy to give ya a buck or two per gallon for that drainage. Multifuels love ATF! I know it makes mine happy. Let's all be green(er)!are you sure its not Hytrans fluid like the stuff they use in skid steers and other hydrostatic equipment? that looks alot like regular motor oil
