Engine parts. Worth it?
Gcelevator
645
Fort Lauderdale, Florida USA
Hey guys, question for the more experienced ones. I am done stripping the valuable parts of the engine (alternator, steering pump, IP, starter......) i got to the point of removing the pistons and crank shaft, is it worth it to remove and save for a future non running project? Remember, 1 tie rod is bent. This engine had only 7 miles from rebuilt. Opinions? What would you do if it were you?
Hummer Guy
804
United States Louisiana
Just saying, if it was me, I'll take every possible thing off of it, you never know what you may need in the future
Coug
4,247
Olympia/WA
Hard to say.
If you have plenty of storage space for chunks of metal you'll likely never need, then yeah, it's worth it. I still have an Olds 455 block sitting out in the garage from a high school project decades ago.
on the other hand, it's very unlikely that you will ever need to use the pistons or crankshaft.
Usually if the pistons and/or crankshaft failed, the block is also damaged, and buying a used or rebuilt engine is a lot more cost effective than fixing everything wrong at that point.
I'm leaning towards "not worth the effort or space" if it was my decision.
Hummer Guy
804
Hard to say.
That's smart thinking, I wish I was like that, I'll try to get everything off of it but that also explains why my space is going low and I need to get rid of some of my junk
