Engine splash guards
jmpogue89
35
Houston Texas
I can make duplicates of the splash shields if yours are damaged or missing. ......... The rubber matting is a little pricy. Its 1/8” thick. ...........
The rear shield on the driver’s side was missing, so I made it to protect as much as possible. If you do want them you will have to make your own holes because I believe they are all different due to there being an extra hole in the shield for the right front. I’m guessing it was stolen from another vehicle. C5F87468-0BCE-4586-A7BE-AC65D4AF428A.jpeg4A4831C6-11CE-4765-9966-7DEFD4CDE19E.jpeg703929D8-0853-4588-8E03-6571533F6AD3.jpeg06BBD77E-76B8-4DA6-93DB-7A18D6D5D670.jpeg
killjoy35
Davenport
The rear shield on the driver’s side was missing, so I made it to protect as much as possible. If you do want them you will have to make your own holes because I believe they are all different due to there being an extra hole in the shield for the right front. I’m guessing it was stolen from another vehicle. View attachment 787081View attachment 787083View attachment 787085View attachment 787084
PM sent
