- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Question for you guys, who have made the engine switch from the multifuel to a more conventional engine; was there a change in fuel economy?
How many MPG's before and after the swap, that's the question.
The multifuel engine uses a combustion process, which is more controlled than the conventional, supposedly producing less knock under low load conditions, an overall improved efficiency (more complete combustion) and less sensitive to the kind of fuel burned.
Thanks,
Thanks,
