Engine width
jesuscowboy
alabama
I've been looking for information on the width of the multifuel where the motor mount are attached to frame. I found some info that said width is 29" to 32" depending on the model. So what I'm wondering is that width at the widest point of the overall engine (manifolds, accessories, etc.) Maybe someone would be so kind as to walk out to there deuce (haven't bought yet but looking) and measure width of block where motor mounts attach. Thanks in advance.
jesuscowboy
alabama
so the block is not like a typical mounted engine with motor mounts at a 45 coming out of side of the block; looks like from the pic the ears at 24" are mounting points
FreightTrain
Banned
2,730
13
Gadsden,Al
Nope.2 mounting points on the rear bell housing area like the above and then you have another mount at the front that bolts to teh front bottom corners of the block and is actually a Motor mount and Radiator mount.
