- 7,426
- 2,538
- 113
- Interlachen Fl.
Yep we have a pressure relief valve on the secondary fuel filter and a over flow valve on the head. The over pressure would have to be set higher than 70 psi. The min. working pressure of the system is 60psi. The over flow always flows because of the hole in it. Here the over pressure valve does not open on shut down because not enough pressure at 30 psi idle and over flow allowing pressure release back to tank.James, if memory serves, its around 85psi. I used to use a multifuel secondary filter set to filter my fuel before it went into my fuel tank. Imagine my surprise when the filters clogged and fuel started spraying everywhere cause I didn't plug that pressure relief valve!
Not a happy camper that day...
