Engine won't turn off?
STRIDER
largo/fl
im having to brake and stall the engine because my M35A2 won't stop running? i have already checked the cable for the engine stop it pulls ok just not turning the engine off? any ideas?
AceHigh
30
Princeton WV Lake City FL
No problem. Just leave it running. That way the air will always be up.
Seriously, did you remove the cap where the stop goes into the pump? Mine "jumped tack" once and just needed to be reinserted.
SCSG-G4
PSVB 3003
3,320
Lexington, South Carolina
Open up the fuel stop and make sure it is correctly installed. there are a couple of threads showing how it's supposed to look. Cranetruck has posted the info several times.
ida34
33
Dexter, MI
I think you should be happy it is running. The people with real problems are the ones with the truck will not start problems.
airmech3839
Augusta, GA
I had trouble with mine cause the stop rod was slightly bent and if it is turned one way it wont go all the way to the stop position and the truck will keep running... could also be corrossion on the shaft... maybe not but thats what I have had happen to me... hope you figure it out..[thumbzup]
fasttruck
632
Mesa, AZ
Put in high gear and stall the engine. Park inb neutral so if someone bumps it with another vehicle it does not start and drive off which will happen if fuel valve is open and truck is in gear.
