Engines in the CUCV?
southdave
ripley, oh/TDY Lordstown,Oh
freakin love fest... you all are drank way to much cool aid lol.. the engine was crappy, IMO the concept was still make gas engine a diesel, based upon foot print eventually a crank rod or bear journal may cut lose prematurely.. the engine is crap shoot
Here my experience..
it took 4 Humvee takeout engine to get enough rods to make one engine, found a crank after 3, and two of blocks had crack webs. they all rebuild dates 2006 & 2007 and green tags
Keith_J
1,328
Schertz TX
Does every j code 6.2 have cracked webs? I am thinking that might be from unauthorized use of starting fluid.
Soaper
clarksville tn
almost every 6.2 has cracked webs down in the mains.
its an common problem and most never notice.
goodwrench and theres one other company that made 6.2L later on and there better blocks and they fixed alot of design issues. however there expensive.
Warthog
246
OKC, OK
GM switched to the 6.5L engines and then sold the rights to AM Generals General Engine Products division. They improved the design are still making the 6.5L. Stonepicker1 has the 6.5L Optimizer in his CUCV-II and it is a workhorse.
porkysplace
1,496
mid- michigan
The GM small block gas engines had similar problems but the crack was between the lifter blocks . Lousy engineering and the need to cut weight for fuel standards the cheapened up the blocks to near garbage .
M1009 NEWBEE 2013
Colorado
Sharecropper- Can you dig up the fluidampr part number you used? I was just getting ready to change out my damper in my 009 and noticed your post. I checked but there are several model numbers listed for the 6.2. Dave
Warthog
246
OKC, OK
Yellow tag means it is good. Green means repairs required. Red is junk (not always ;-) )
Sharecropper
1,265
Paris KY
I spoke with a fellow named Ivan Snyder at Fluidampr when I purchased my unit. 716-592-1001. He told me the correct model number for our trucks is "800191, 8" FLUIDAMPR for 1982 - 1987 6.2L GM Diesel".
Hope this helps.
11Echo
96
CT W. R.
It was discovered after pulling the pan number seven rod broke off the piston and punched a window into the water jacket on this "yellow tag 6.5" engine. My friend should have filed a claim with GL as it was listed as good.
After a couple 6.2 engines in my 1008 I went with a gasser.
