MTMUDRUNNER
- 0
- 0
- Ennis,MT
Been working on the ether switch today, here is what I have done:
Checked if I had power to the switch in the cab no, so went to TM9-2320-272-23-1 and found the ether starting system operation. I have power to 5A through the CB and to 27 I could not find 5C so I disconnected 498B from the switch, connected 5A and had power to the switch. Next I went through all the connections from the switch an had power until it goes to the sensor on the block I am guessing it is a temp sensor, so I bypassed the sensor and went to the 570 wire on the bottle and had power to there but it still wont actuate the tank valve so I am guessing the valve is bad. The only problem is when I disconnected 5A I lost the oil pressure gauge (no good), any suggestions on getting power to the switch or where 5C is so I can follow the wiring ?
