Ever see inside the Protective Control Box?
rebelqwes87
Loganville, Ga
I still haven't had time to rebuild mine yet, still using the jumper wire method. Anyway, yesterday I started the truck yesterday to move it and decided to hook the box back up once it was running. After about ten minutes I noticed an electrical smell. The top of my box is off and I could tell that's where the smell was coming from. I felt the top solenoid and it was extremely hot. I suck with electronics, any idea what would cause this. Maybe it could lead to a diagnosis of what died in there?
hklvette
Christiansburg, VA
Definitely some logic on that circuit board. The 14-pin ICs are quad NAND-gate packages. I can't tell what the TO-220 packages are. There must be some kind of voltage regulation on there since the CD4011s are only rated to 20Vdc. No timing hardware that I can see unless it uses an RC circuit to do the job.
todds112
Teton Valley, ID
  • Definitely some logic on that circuit board. The 14-pin ICs are quad NAND-gate packages. I can't tell what the TO-220 packages are. There must be some kind of voltage regulation on there since the CD4011s are only rated to 20Vdc. No timing hardware that I can see unless it uses an RC circuit to do the job.
Yeah, that's what I was thinking. ;-)
Artisan
227
CDA Idaho
There is no doubt in my mind that if a guy could hands down
say for SURE that he could rebuild these things, tested A-Ok
to factory specs that he would have a nice little side job...
Soldered connections in lieu of crimp and quality control...
as in TESTED prior to sending out.
Eaglhawk
17
Grantsville, Utah
Just a little hint on those 24v relays. Most manufactures have the silver contact option for them. It is a little more expensive but they handle the spark from engaging and disengaging without pitting as bad... And at $5 to $10 dollars more It is definately worth it... Usually the part number is the same with an added letter or number to differentiate the contact material....
cabalaro
Branford, Florida
24214 24V 200A Continuous Solenoid
200A with silvertungsten carbide contacts.
Normally Open Contacts,
spst, One circuit: Off - On
Housing: Plated steel.
Could not find any with silver
they are 55 each on ebay
TexAndy
Bee County, Texas
FYI, my 923a2 wouldn't start a few weeks ago. Keithj happened to be down and he diagnosed it. It was corroded contacts on the load (not coil) portion of the ignition relay inside that PCB, IIRC. We were able to start the truck by shorting around the contacts with an insulated wire. I wouldn't recommend it if you don't know what you're doing, but starting the truck was enough to cause the current to clean the oxidation off the contact points so I could start it normally after that.
cabalaro
Branford, Florida
here are the Photos I promised. After changing out the solenoids and reusing the diodes it works flawlessly ABS, light, everything that was not working now works and it fires right off. Takes about 2 hours to do the job, cleans and repaint the inside for corrosion prevention and put everything back in. Remember to keep everything referenced to the way you removed it and the diodes in the right direction. Its a pretty easy repair and a lot cheaper than the new or used boxes. $40 fixed it I have 3 more sets if anyone needs the solenoids20150304_102724.jpg20150304_103138.jpg20150304_103152.jpg20150304_104416.jpg20150304_104441.jpg20150304_115047.jpg
5tonbrian
United States
i just purchased the 2 of the solenoids and I am dead in the water. Reused the old diodes, the battery and lights and gauges all turn on but nothing to the starter. Any help would be greatly appreciated!
Artisan
227
CDA Idaho
The starter itself is OK? You have verified this w/ a test?
