Excessive oil pressure m925a1
ROCKWELL-C60
192
franksville wi
Recently took my truck out of hibernation and my oil pressure reads 80 at idle 95 at speed. Everything seems fine and I don't remember what it ran at b4 but I'd think I'd Remember something like this. I haven't changed the oil yet but will soon. Any ideas, do these guages mess up like this
Swamp Donkey
The Engineer
120
Gray, GA
If still using the original electric gauges, a weak ground will cause a high reading due to higher resistance. Very common problem with the way they grounded the gauges to the panel, and the panel to the dash. A ground wire directly from the mounting stud on the gauge, going directly to the dash, will fix future ground issues. Same thing for the temp and fuels gauges. I did all mine several years ago and while accuracy might be debateable, at least they're consistent now. Consistency is about the only thing I ask of them, lol
My truck runs around 80 psi cold and around 50 psi when warmed up at idle, with full throttle being around 65-70 psi. As 98G said, your pressures don't seem unreasonable.
Slate
378
Ozona Texas
What is a normal idle oil pressure on the A2 with the Cummins 8.3?
Sent from my moto z3 using Tapatalk
98G
Former SSG
4,428
IIRC, spec is 8psi at hot idle. Typically you'll see more like 30psi.
