>It takes a few guys a few minutes to pushout the walls and get it set up.<
I can open mine in 15 min by my self (less if it's raining)
>MAKE SURE IT WORKS. When the walls didnt work, it was a nightmare to get it fixed.<
A friend of mine has one that's borked. The middle two side-wall racks are out of time and the side walls are bowed (one in and the other out). We may end up scrapping it and make a LWB covered wagon (m36?) out of it.
It weighs 8800 pounds. If you have to lift it, hire a crane and use the lifting shackles. even at that weight, the T.O. still says I can put 5000lbs on the floor and another 10,000 on the hitch. I've had an M-37 on the hitch and almost never got into high gear. Climbing a hill on a state two-lane highway, at one point I was into low range and down to 3rd gear. She's a non turbo, I was making a LOT of smoke. The M-292a2 is WAY heavy, the only reason they were mounted on a duce frame is so they'd fit in a C-141.
