Extended Cab 4 door.
4x4e350
Vestaburg, Mi.
The pics of the back look great. One little piece of advice, though. You may want to mount that milk crate to the floor. Could get a little rough back there for your passengers! :wink: Great work!
OK, I took your advice, I made a frame for the rear seat.:-D
I also made a frame for above the cab, I want to be able to hook the top up to a pulley system, and lift it off, so I figured a frame system would be needed to support the weight. I also used 4 bow tie downs for a boat, they have #6000 weight capacity, so they should be able to hold the weight. The frame also helped straighten all the metal a little better.:smile:
Then I started making a new front grill, the old tubular one was pretty beat up and rusted. Plus I wanted a little more protection for the fenders. I'm not sure I like the look yet, but I can always modify it if I need to.:?:
jamesfrom180
71
Gainesville/Florida
your rear window solutions reminded me of older train passenger windows. Used the same idea but had a brass barb and used a leather belt so you could have multiple positions for the height of your window. I've seen the circle and US tooled belts around, that would dress up the cab a bit. Alittle Calvary brown leather and brass would look good with those seats.
Not sure I like the cant to the grill? I'm thinking the flat looks better. I like the build so far. Definitely need to keep the option of going topless.
4x4e350
Vestaburg, Mi.
I actually found a green tie down strap from TSC, the kind that is adjustable at any length I'm going to use for the rear windows. I plan on finding some green canvas, to cover the rear seat with.
I agree with you about the grill, I'm not sure I like it either:neutral:, maybe it'l grow on me?
Looks great so far Brad, I'm letting you get all practiced up so you can do mine. I'll have to stop over and put a eyeball on it soon. Joe
Thanks Joe. Your truck is too nice to cut up, I'm not sure I could force myself to take a cutoff saw to it;). Your welcome over anytime on the weekends, I'm usually always locked in my Pole barn.:lol:
O.D. Fever
Howard City, Mi.
Brad I have a few hundred new half tents in the factory boxes, they make great seat covers or cot canvas. stop over and I'll give you what you need for seat covers. Joe
4x4e350
Vestaburg, Mi.
Looks awesome!! What is that behind the 5th wheel? Looks cool as well.:drool:
To make a long story short, it started out as a Dune Buggy I bought for $300, which originally came with a VW motor. I ended up going through a divorce, and had no money to rebuild the VW stuff. So I used a bunch of left over parts I had from previous projects, it is now a Turbocharged propane powered Ford 300 straight six, with 1 ton drive train. Really just a bunch of left over parts put together, from what I had, and could get cheap off craigslist. I tried to make it with a military theme.
FatBuddhaBoo
Jacksonville, Fl
Definitely one of a kind...great job!
Can you post some pics showing how much leg room there is in the back section? I'm assuming it's a little less than a full crew cab conversion, however, I'm thinking if the vent section was not there and you left the full doors on it it would be about the same (as that's what I'm considering doing).
