Extension to speedo cable?
Trango
23
Boulder, CO
I've successfully moved my transfer case back a few feet to accomodate a new drivetrain, and I am in the hunt for an accurate speed reading.
The end of the speedo cable is perhaps 2 feet away from the mating connection on the transfer case.
Any thoughts on how I can make this connection? Some thoughts I had:
- Is there a longer cable available on perhaps a 5 ton or another MV? What about the tach cable - is that made from the same stuff?
- Is it possible to find some sort of intermediate connection?
- Finally, is there civvy interchange, so I could just buy the length I need?
Thanks for any and all ideas.
Best,
Bob
Stalwart
33
Redmond, WA
I'm pretty sure if you do a search on the internet you can get a new one made without too much trouble. You'd probably need to send your old one in, so they could make sure the ends are correct.
Unforgiven
Las Vegas, NV
I think some of the 5 Tons fit. They should be about a foot longer. Call up an MV supplier/salvage and they should be able to tell you. Otherwise, order a custom cable on the internet.
