External trans cooler fluid offset
firecontrol86
San Diego, CA
This might sound stupid, but I'm going to install an aftermarket external transmission cooler in series with the one in the radiator. What I'm wondering is adding that extra bit of tubing going to hold enough ATF that I will need to add some to make sure I have enough fluid? Thanks in advance.
bushhawg73
Columbia, Missouri
I would check the level after the install, if I had to guess I would say you are going to need at least 1/2 to one quart to add. It really depends on how big the cooler is, how long the lines are and how much fluid you spill when you cut the factory line.
kapnklug
spencer,ny
I'd say after it's all hooked up, crack the seal on the return line to the tranny and crank the engine (with pink wire removed) until fluid seeps out. Then replace the wire, start the engine, check the fluid level running, and top off if necessary. This will prevent a "dry-start" for your tranny.
