- 7,408
- 2,501
- 113
- Interlachen Fl.
I am guessing that the after market rubber trim for the fenders is extruded. Now the new rubber that just came in has a set to it that is backwards. Does this set happen when it is extruded or when they coil it up? The reason I ask and also saw a post about it is the way the new rubber came is backwards set to the way it needs to be installed. I did not think it would work well but I bent it and secured it with the bendy rivet thingy's and install it. It seems to work it's self out. In the one pic you can see how it is supposed to lay on the fender and access panel. The other pics is the new laid next to the old piece. If my pics came out then you can see how the two do not match up as per the set and lips. Tanks
