Factory dummy lights
pevrs114
32
Monroe, NC
Gents,
Can you tell me what the factory dummy lights are on the CUCV trucks?
I specifically need to know what the ones around the speedo/fuel gauge are. The ones I've seen so far are 4WD and WAIT. I know that some civilian trucks from this era have the BRAKE light underneath either the speedo or the fuel gauge. I know the CUCV has it as one of the 4 large dummy lights on the left of the dash, does it have an unused, unlit BRAKE light in the center as well?
I need to rig up a BRAKE light indicator to pass VA inspection, I would prefer something clean and factory but need to do it quick.
Thanks!
319
Lieutenant
49
Michigan
I should add that all your lights and gauges normally work. If they do not, remove the instrument cluster, clean the connections, check the bulbs, and the grounds.
pevrs114
32
Monroe, NC
Re: RE: Factory dummy lights
Well, that's what we ended up doing. We started by checking the fuse, then the switch behind the parking brake, then we removed the dash and pulled the bulb (it was ok) then we pulled the instrument cluster. A bunch of the connections in the plastic wire harness that's glued to the cluster were broken. We bought a few jumper bulb kits from the parts store and rewired them back to the harness so that they work.
Good to go!
Thanks for the help guys
CCATLETT1984
Saint Clair Shores, MI
RE: Re: RE: Factory dummy lights
the plastic board is known for issues. its mainly just age and heat that cause the issues. I have a few burnt out dash lights that i need to replace one of these days.
maritimer
Yarmouth, NS
yeah i only have the following idiot lights that work, wait, water in fuel, gen 1, gen 2, fasten seat belts * that only started working after my girlfriend took it swiming* the brake light does come on when system is dry but thats it. still havent figure out how to get the 4x4 light to come on
