Fan Clutch Hose Disconnect
oldandintheway
Lexington, KY
Does anyone have any experience with leaking power steering fluid leaking through the quick disconnect at the fan clutch hose? I understand some people have had success using plumbers putty instead of plumbers tape on the threads. Any help is much appreciated.
Mogman
10,399
Papalote, TX
It is normally the female connector that is the problem, it is the one on the hose (normally) the seal goes bad in the connector, BUT that is just what normally is the issue, careful inspection is required.
If that is the problem you just replace the connector, no way to fix them.
HoveringHMMWV
1,341
AL
I just did this repair. See post #: 5,924 .....
This is what I ordered......
Successful repair. No drips afterward.
