kfrosty
- 7
- 0
- Belmont, NC
I've got my second Hmmwv out of 5 so far that the fan doesn't kick on at 215 or whatever.
The only things that effect this are the temp sensor in the water cross over, the Time Delay Module and the Cadillac valve, correct?
If I unplug the connection to the TDM, then the fan comes on and stays engage.
My understanding if one of the above was bad then the fan would stay engage. But it's just the opposite. So I thought it would be the Temp sending unit in the cross over. I've changed that out with a couple of others. (I just ordered to new ones to be sure.)
Has anyone had a similiar issue and it turned out to be the TDM or cadillac valve? I'm assuming it's not bad because the fan will come on if I unplug the TDM.
Thanks
Thanks
