Fan stuck ON
Autonomy_Lost
1,554
Pennsylvania
Okay so I think its fixed. I replaces the fan switch with a REM one, and now the fan kicks on at the middle of the green arc, and kicks off at 185 degrees which is the bottom of the green arc. Does this sound correct?
Mogman
10,602
Papalote, TX
Jumping in here because I'm having an issue too now. But its weird.
The other day my fan failed to come on, and my temps kept climbing. I unplugged the TDM module which made the fan come on. Then, as a troubleshooting step, I plugged the TDM back in, and unplugged the temp switch (the one by the thermostat housing). That also made the fan kick on, leading me to believe the temperature switch is bad.
So I replaced the temp switch with a new one, and at first I thought the problem was fixed because the fan kicked on at the exact right time, but then never turned off. What the heck!
The system is "failsafe" so with the switch open or the wire disconnected the fan runs, it shuts off when the switch closes or you short the two leads together.
Ajax MD
1,437
Mayo, MD
Holy thread resurrection, Batman!
My fan is also stuck on. I know the preliminary troubleshooting steps. It could be as simple as a stuck clutch from little use during the winter.
Ajax MD
1,437
Mayo, MD
Looks like my fan clutch is stuck. I've applied 120psi air, no clutch movement, no change.
I've tapped on it a little. Any other suggestions?
4x4Junkie13
29
La Vernia TX
I know this is an older post but….
I am trying to diagnose the Cadillac valve itself.
If I apply 90psi to the supply side of the valve it pushes air out the back of the valve.
If I apply air to the other two ends I get nothing.
Does this mean the valve is closed and that is the way it is supposed to be or should I be able to blow air straight through the valve with the truck off?
Mogman
10,602
Papalote, TX
Not surer what you are calling he supply side.
Without power it will allow flow back towards the return line to the pump from the clutch and supply side, it only applies flow from the high side of the valve to the clutch to disengage the clutch, it is also regulated within the valve so blowing air though it has no real diag value that I know of.
