FAQ Thread for CUCV's
Mohawk Dave
14
CA
updated cheat sheet for CUCV
I am making this for myself (and you guys) to carry in my OH9. It's not perfect, but I hope it helps. (I'd say copy and paste from here below) and if you make changes/additions, repost please. Thanks.
This Infornation was obtained from the SteelSoldiers Website
BELTS:
All W/O AC
· Driver side alt- Gates# 7575; Dayco# 15580
· Passenger side alt- Gates# 7483; Dayco# 15490, Goodyear "Gatorback" - 15485
· Power Steering- Gates# 7448; Dayco#15455
AIR CLEANER:
· Any standard filter designated for use in a K5/K30 will work. FRAM# CA3492; NAPA# FIL2096.
HOSES:
NAPA - Upper: NBH7995 Lower:NBH7996
ALTERNATOR:
DRIVERS Side Alternator #7157
Off the shelf replacement alternator for drivers side ONLY.
1975 Caddy Commercial Alternator
100 amps
Ultima - Alternator
Part Number: 01-0136
Our resident CUCV wiring expert, Warthog, assembled my M1009 out of 3 or 4 donors. The wires were all cut off for the alternators and the alternators were not on the truck. One of the reasons I got the truck was that he had new or rebuilt ones on it. I get it home and realize ALT 2 isn't charging.
Now, having read about 20 post a day for the past 5 years about CUCV alternators. I "knew" if the red ALT 2 light wasn't coming on before engine start, the bulb must be burned up which causes the alternator to not work. Mine wasn't coming on, ever, so that must be the problem. I got the truck with no dash or cover on it. I of course didn't figure out the alternator wasn't working until I installed all that stuff.
I called up Joe. He told me to do what I would have done with any other vehicle besides a CUCV. Check voltage at the alternator with the key off and with the key on.
Each alternator is a 12 Volt unit. The big red wire that is bolted on has 12 volts from the battery. The little white plug has 2 wires on it. The thicker is the voltage out of the alternator back to the battery. The smaller wire is the exciter wire.
With the engine off, the big red wire should have battery voltage, so should the bigger wire on the plug and with the plug off, key off, the exciter wire should have nothing.
Turn the key on and the plug off, the exciter wire will have battery voltage along with the other 2.
The above should be your first check of a suspected bad alternator. This tells you if the problem is in the alternator or in the truck. After making sure all wires are hooked up and not grounding out somewhere that is.
My truck side was working properly. I had a problem in the alternator. I called Joe up and asked about the red ALT 2 light. I "knew" it had to be part of the problem because I had read about it here on SS for so long. He kept telling me to ignore the red light. I kept telling him I couldn't, even though it didn't make sense. He told me to look up the -30 procedures for testing the alternator inards and to replace what is bad.
I pulled the alternator off, looked up stuff in the -34 and was lost. They wanted me to build a variable voltage machine just to check out the voltage regulator. I don't have a variable voltage source, so I just threw in a known good regulator and put it back on the truck. I didn't turn the page in the manual to check out all the other components. I took care of the first thing listed in the manual.
The alternator didn't work and the silly ALT 2 light still wasn't coming on. I just knew that ALT 2 light was part of the problem in some way. I still drove the truck though.
Maybe I should cover how you can drive a truck around with a bad alternator and it not be a problem. CUCV's are 12 volt Chevy trucks at heart. The wire for the engine to run, the lights, the blinkers and all that are all 12 volt. The drivers side alternator, ALT1, runs that part of the truck along with the front battery. As long as ALT 1 is good, the truck will drive until you run out of fuel.
The passenger side alternator, ALT 2, only has to charge the rear battery up after the truck has been started. The starter is the only part of the truck that uses the rear battery. I had probably 30 starts on the truck without the battery getting charged. The volt meter was at the top of the yellow zone and the starter turned over at the same speed every time. That was 2 weeks of in town driving without ALT 2.
Since I didn't have the variable voltage thingy machine to test out the alternator, I broke down and paid $44.50 for a complete 27si rebuild kit. All new everything inside the alternator. I put it on and turned on the key. The ALT 2 light lit up. I fired up the engine and the voltage gauge was in the green for the first time since I bought the truck. A volt meter at each battery showed 14.4 and 28.8 across both. It was working.
But, what was wrong? I still had a suspicion that I had hit the dash or something making the light come on and therefore the entire system work. Even though Joe and my test showed the trouble was in the alternator.
I put all the parts I pulled off in a bag and went looking on the Delco Remy site for their version of a test. I posted a thread about the manuals there. They word the test different and I actually turned the page. The Diode Trio and the rectifier bridge can both be tested with a simple Ohm meter. I put new of each in the alternator.
I got out an Ohm meter and tested the Diode Trio I had removed from the alternator. Very simple instructions. Put one lead on the long leg and the other lead on any of the 3 shorter legs. Look at what you get and then switch the leads. One way should be high and the other low. If they are the same, the Diode Trio is bad. My just removed Diode Trio had the same value on all 3 legs with the leads reversed. Bad Diode Trio.
The test for the rectifier bridge is the exact same thing on it. Mine was good.
If you have read this far, you get the summary.
If you are not getting voltage out of an alternator, no light before start up or during running, the exciter wire is exciting and all the other wires are correct. Then I would suggest you spend the $4.00 or so for a new Diode Trio for a 27-si alternator, put it in and go find something else to work on. Or at least read all the pages about testing the alternator parts, test them and then figure out what is bad.
I would look for loose or grounding wires if you have an intermittant fault. The Diode Trio is a solid state component and it pretty much a good or bad. Not a sometimes.
Does your volt meter move up or down with the light showing up or not?
I ask because the si alternators just need the exciter wire to work at start up. Which means as long as they get "turned on", and the engine stays running. They will continue to charge until you turn off the engine. Yours are working, so something somewhere on the truck side is probably either shorting out or not staying connected.
Do the test with the plug on the back of the alternator checking voltage key on and key off. That will tell you to look at the truck wiring or the insides of the alternator. I suspect you will have a loose wire somewhere in the truck harness.
1.Bad belts
2. Misaligned/damaged/dirty pulleys
3. Bad batteries
Bad batteries was my first thought as well. What kind of voltage do they have with the engine off? Check that, then start it and see how far they drop while starting. The 1/2-1 second it takes to start a 6.2 should not drop them down much below 12.0 volts. Anything below 11.0 volts while cranking means you have a battery that can't handle any load.
With the pulleys, look and see if they are shiny all the way down inside the groove. The pulleys are just stamped steel pressed together. As they get old, they sometimes flatten out and the sides of the V on the belts don't make contact anymore. The skinny bottom of the belt is what is turning the alternator. Not near as much surface area, you will get slippage and a belt that stretches and wears out fast.
STARTER:
starter bracket PN GM 22502557
I have ordered from www.gmpartsdirect.com before. Shipping is a little high.
The gear reduction bracket is 23502557 - $15.28 list
The direct drive bracket is 14028931 - $3.32 list
The Starter bolts - 15544950 - $2.80 ea (must buy a box of 5)
The bolt for the braket to block - 14060613 which is a M8 x 1.25 x 20
Gear reduction on the left, direct drive on the right
The part number for the new style gear reduction bracket is 23502557.
It has been listed in 12 differnt treads. Here are a few.
Starter bracket by Gm Discontinued once stock depleted
Broken starter both problem
where can i get a m1009 starter in or near dallas tx.
Starter Support Bracket
The Diode/Rectifier that is used in the Starter Relay circuit and the Gen2 circuit,
is GM Part Number 12006377. Since GM doesn't stock it anymore, Keith_J found a Radio Shack part that works. #276-1144
I would rate this as the third most common problem, but probably the most expensive one if you don't know what to do when it happens.
CUCVs have an extra starter relay under the dash. It is known to either rust and not work making the truck not start or to stick in the on position letting the starter run until the wiring harness or the starter itself burns up and is permanently damaged. You should read the two links below and the links mentioned in them before you even put batteries in the truck. This is probably the most important thing to know and to think about so you will know what to do should it happen to you.
The relay is mounted to the plate that the big plug is mounted to under the edge of the dash next to the 4WD lever. It is the bigger silver relay next to two black relays. Its purpose is to switch the 12v single from the ignition switch to 24v to trigger the 24volt starter. It has four wires plugged into it, The red wire is 24 volt feed. Solid purple goes to the starter. Black is ground. Purple with white stripe is the ignition feed. You can unplug these and jump the red to the purple and start the truck in an emergency. There is a post further down with the part numbers.
GLOW PLUGS:
NAPA - ST85
Or
Ford Powerstroke relay
NAPA - ECHGPR110
Good discussion about the differences between the GPRs
http://www.steelsoldiers.com/index.p...ic&t=21485
The main problems with CUCVs are charging issues and glow plug issues. The original glow plug relay was defective and should have been replaced before the truck left the service. If you have one that looks like the one in last two pictures, you should replace it. Most come out of the service with one like in the third picture. Some of the dealers here have had them in the past. The first picture shows one I got at NAPA. I used ECH GPR109 for $28.49. It looks just like the ECH GPR110 but it is $85.49.
The ST85 looks like what the military went to and is $54.49 at NAPA online or 45.20 at the local store. It also shows one way to bypass the voltage dropping resister. Here is a link to some pictures I took when I replaced my last relay with a ST-85. The old one is what came with the truck from the military.
http://1plant4u.smugmug.com/gallery/...94046840_RAMog
Glowplug relay comparsion - Michael's Photos
The 109 and 110 relays will bolt up with the same holes as the original relay. They don't come with nuts on the posts and they aren't the same size as the original so you will need to get some while you are at the store.
The bid red wire goes on one big post and the two big orange go on the other.
The small blue is on the top small post and the small pink is on the bottom.
I don't think it makes any difference if you get them backwards since the two small wire energize an electromagnet which closes a connection to connect the two big wires. The above pictures was from a truck as it was released from the military.
In the pictures titled NAPA relay, I have run a large white wire to the 12 volt buss to bypass the voltage step-down resistor.
Do not buy AC13G glow plugs. They are obsolete.
The correct direct replacement plug for the cucv is Wellman 070
I prefer AC60G which is what GM recommends for all civilian 6.2 and 6.5 engines
One of the threads above references the NAPA GPR109 glow plug relay. This part is meant for pre-Powerstroke Ford diesels. It is $25 or so while the GPR110 which is very similar costs around $85. We're not sure what the difference is between the two but even the local NAPA couldn't tell me other than to say "$60 more". I used the 109 and so far, so good.
There are two small issues with using the NAPA Ford GPR109 relay, both of which are perfectly fixable.
1. The brackets on the stock relay are of a "north and south" orientation with one on the top and one on the bottom. The 109 has them in a sort of "north and west" orientation. All I did was put the north bracket in the stock hole and then drill a new hole below the stock lower hole to mount the west bracket with. I just couldn't turn it enough to use the stock lower hole without hitting the brake system stuff there to the right of it. Some people have reported they were able to get theirs to line up with the stock holes without trouble but I was unable to do that with mine. Might just be me.
2. The 109's larger studs use different threads than the stock relay's larger studs do. You will have to go out and find new nuts because of this. Minor but it is something to take care of before you're kneeling on the radiator shroud, stretched across the engine cussing.
The two smaller stock studs use the same thread as the 109's smaller studs so their nuts can be reused on the 109.
Note that this is for the original style relay these trucks came with from the factory. I do not know if the updated relay the military used was different.
The wiring diagram for the CUCV glow plug system are incorrect. If you are replacing a missing Glow Plug Relay, the small orange wire goes to the glow plug side of the relay, not the resistor side as shown on the wiring diagram. If it is on the resistor side, the controller will light up the wait light, but will not activate the relay.
LIGHTS/BLACKOUT LIGHTS:
· The right toggle switch moves power to the service lights, horn, dash, etc. or to the blackout lights. Pull it out and flip it up or down.
· The left switch turns on the blackout drive light. Flip it up or down; it will return to center position.
BATTERIES:
· Group 31 or 6TLs
OIL:
· Oil is 15W40 for diesel. Rotella is available in gallon jugs and quarts at just about any convenience store or truck stop. Engine capacity is 7 quarts.
· Oil filter is FRAM# PH13; NAPA# FIL1092; ACDELCO# PF1218CL; K&N# HP-3002
· Oil and filter change recommended every 3 months/3,000 miles
TRANSMISSION:
(TH400, 3-Speed)
· Transmission fluid was indicated as Dexron II. This has been replaced with Dexron III.
· Transmission filter is NAPA# ATP14558 (or 19701 w/gasket); FRAM# FT1020A (w/gasket)
· Capacity is 4 quarts. But this may vary. Fill as needed to reach level.
· Drain/Fill and replace filter every 2 years. Do more frequently if regularly using off-road or for towing
Transfer Case (205 & 208)
· Fluid is Dexron III
· Capacity is 5 quarts.
· Level should be approx. 1/4” below edge of filler plug hole
· Drain and fill every 2 years/24,000 miles, or annually if under heavy use
Front/Rear Differential
· Valvoline 80w90 is preferred
· Front capacity is 4.5 pints.
· Rear capacity is 5.4 pints.
FUEL INJECTION:
Fuel filter is NAPA# FIL3136; FRAM#P3940A
The IP is a Stanadyne Roosa Master DB2
If you decide to do a spin-on fuel filer conversion, you can use a hand operated vacuum pump (the same kind for bleeding brakes) to draw fuel from the tank and through the new element. Just hook the hand pump to the filter's output fitting to the IP and pump it a couple dozen times until you get a clear stream of fuel, then reattach the IP/filter line. It only takes a minute and gets rid of all of the trapped air.
If you would like to add an electric fuel pump to make fuel filter changes, water draining, priming after repairs, etc... easier, then you can use a 12v electric pump from a late 80's 6.2L civi truck. I wired it with an inline fuse to an ign. on circuit on the fuse block and used GM weather-pack connectors to make it look factory. I used it like that for 8 years without a problem. Just make sure to use an inline filter before the pump to catch any trash. Change it when you change your primary filter can. Also mount the pump on the frame close to the fuel tank so the fuel with keep the pump cool and it will also be less likely to suck air through a pinhole in the line. It's always easier to find a hole in your fuel line with a drip.
prob want to put this in the sticky in the hmmwv and Cucv threads but you can get them from about any parts store. I called Napa, Autozone, Advance, and orielly. they could all get it.
Dorman 904-101
it was $9.52
This is the kit that will get you all the little rubber flex lines that go on the injectors and the clamps that hold them on. Does not come with the caps for #7 and #8
when replacing the fuel lift pump on the cucv the little mettle rod that actuates the pump must be inserted fully into its little hole to get it to stay up in place put a little wheel bearign grease on the end that slides in
KEYS:
Key "B" blank 73Y2 cut
WATER/THERMOSTAT:
The Hockey Puck thermostat for the CUCVS are available at NAPA, Autozone and Oreilly's (and others of course).
NAPA - 381190
Autozone and Oreilly's - Murray 42995
Thermostat housing gasket - Felpro 35271, Murray 2140
Thermostat Housing (Water Outlet) - Murray 84987
ELECTRICAL:
If you are troubleshooting the CUCV electrical system, the wiring diagrams are in the Appendix of the Tech Manuals. Appendix F of TM 9-2320-289-20 and Appendix E of the TM 9-2320-289-34.
Also if you need instructions or a refresher on how to read the diagrams, read the first few pages of the TroubleShooting section of the above manuals.
They cover how to read the diagrams, wire labeling, wire sizes, colors, etc.....
I have cut and pasted each of the diagrams, and saved them on my hard drive. When I am troubleshooting a system, I open the diagram up in MS Paint and color the wires to make the diagram easier to read.
CDR-PCV VALVE:
GM - 25042462
NAPA CRB229143 is the incorrect valve...
This is a good discussion about the replacement valve.
http://www.steelsoldiers.com/index.p...ic&t=21492
CDR valves are important but unfortunately not supported in the aftermarket and GM wants an arm, a leg, and something else (or two) for them.
These should be replaced every 50k according to GM (correct me if I'm wrong) but the diesel gurus seem to agree that much more frequent intervals are better. However it seems like they aren't common in the aftermarket as a replacement part. Pretty much the GM/AC Delco route is the only one any of us could find in my CDR thread.
The correct GM part number for the military spec'd part is 25042462 with AC Delco calling the same part the CV871. The part listed for a 1986 Chevy K30 6.2L civilian truck is a 25042248 in the GM parts book and a CV870 according to AC Delco. GM and EVERYONE else list the military spec part as obsolete and it's a dead end. The civilian part could not be located at NAPA, Advanced Auto (Kragen/Schucks/Shumers), Auto Zone, CarQuest, and two local places here in Traverse City, MI. The only locations I personally could find them were my local GM dealers at $71 each and www.Rock-Auto.com for about $41 delivered.
I have a feeling these are becoming a rare part as the box I received is definitely old having the older AC label on it and the date code on the box being from 1997. Others have alluded to getting the part from different suppliers but I haven't tracked this down. I'd definitely consider mine NOS.
The civilian part bolts right to the CUCV's mount and the hoses hook right up to it. Mine had a slightly different angle on the pipe that curves out and away towards the front of the truck but it might just be a manufacturing deviation and didn't pose any sort of problem.
HEATER:
The heater blower motor from NAPA is the heavy duty one. The blower motor part # from NAPA is 655-1076
POWER STEERING:
Power Steering Pump bracket part number is
GM# 14033879
VIN #:
Does your vin number contain HD in it?
Like this, 1GCHD34J0HF311237 (should have front locker)
or is it like this, 1GCGD34J2FF439536 (does not usually have front locker) There's only 1 exception to the 4th digit being a "H" and that applies to the M1010 which has the "H" because of weight but does NOT have the "Trac-Lok" front D60. All others with the "H" came with the "Trac-Lok".
TROUBLESHOOTING:
In order to properly troubleshoot a Stanadyne DB2 application, you must insure the following conditions are met:
1) Voltage – You must have the correct voltage to the shut off solenoid and to the cold start advance solenoid.
2) You should also have the pump properly timed. Please refer to the manufacturers timing information for complete timing instructions in the tech manuals.
3) You should also have a solid stream of return before the pump can achieve starting capacity. Return can be measured here. You can also attach a clear line to check the return for air bubbles here.
4) You should also have a minimum of 150-200 cranking RPMs. If your batteries are weak and you are not attaining the minimum cranking, your vehicle will not start.
INJECTION PUMP BLEEDING
Once you have satisfied these four requirements, the injection pump should be bleed. This is best done by attaching and properly tightening the lines at the head of the injection pump, and loosely attaching them at the injectors. As you are turning the vehicle over, you will begin to get a fuel foam, a mixture of air and fuel, coming out at the line connection, at that time go ahead and lock down the line nut to the injector. Repeat procedure until all lines are bleed completely.
If after doing this procedure the vehicle does not start, please do the following:
1) Attach a clear line to the return side of the injection pump and inspect for air bubbles. If you have air getting into the system, correct the problem before proceeding.
2) Attach a hose directly from the injection pump to an alternate source of fuel. You will need approximately 2-5 gallons for this test. You will need to bypass the entire fuel system, including the lift pump, for this test to be done properly. The injection pump has an internal supply pump that will pull fuel from the source.
GENERAL:
CUCVs use metric bolts so you will need metric tools to work on them.
You can find all the GM part numbers you will ever need in the Technical Manual Parts listings.
TM 9-2320-289-20p and TM 9-2320-289-34p
if your expieriencing vibrations at low speeds try rotating your rear driveshaft 180* on the pinion.
Unless the engine is in rough mechanical shape or on it's last legs, it should see a redline of 3600rpm... but after about 2400-2500rpm, you're losing power & wasting fuel. IIRC, max torque occurs in 1800-2200rpm range on a 6.2 -
Mohawk Dave
14
CA
part 2 of cheat sheet
This information was obtains from the SteelSoldiers website
The M1009 is a 1986 K5 Blazer with a 1 Ton J code 6.2L instead of the normal C code 6.2L diesel and a TH400 3 speed automatic instead of the TH700R4. These modifications were done at the military’s request to make all engine/transmission components the same between the 1008 and 1009 trucks.
The M1009 has Corporate 10 bolt axles front and rear with 3.08 gear ratio and a Gov-Lok in the rear. The front axle is open.
M1009 specs:
Fuel System
· Diesel. #2 Diesel does not have the same lubricity properties as older varieties. Many users recommend a diesel additive. Use with discretion at your own risk.
· Fuel filter is NAPA# FIL3136; FRAM#P3940A
Oil
Coolant
· Engine coolant is any standard ethylene glycol. The Lube Order indicates a 50/50 coolant/water mix for normal use.
· System capacity is listed as 25 quarts.
· Drain, flush and fill every 2 years, or 24,000 miles
Transmission (TH400, 3-Speed)
Brake Fluid
· Fluid is DOT5 silicone only. CAUTION: You can use DOT3, as there are numerous arguments for using either kind, however, do NOT mix them.
· Level should be ¼” below lowest edge of each filler opening in master cylinder
· Check monthly
Power Steering
· Fluid is standard power-steering fluid.
Air Cleaner/Filter
Tires
· For the M1009 the stock tires are Goodyear Wrangler ATs 31x10.50-15
· Tire Pressure should be 40 psi (this is stenciled on the fenders as a reminder!)
Belts
Batteries
· Group 31 or 6TLs
Injector Pump
· The IP is a Stanadyne Roosa Master DB2
Lights/Blackout Lights
Towing
· Listed capacity is 1,200 lbs, with the M416 trailer as the only approved military trailer
NEW SECTION:
Fuel System
  • Diesel, of course. #2 Diesel does not have the same lubricity properties as older varieties. Many users recommend a diesel additive. Most commonly used/available is Diesel Kleen/Power Service or Howe’s. Use with discretion/at your leisure/at your own risk.
  • Fuel filter is NAPA# FIL3136; FRAM#P3940A
  • An alternative spin-on filter is available and requires a base and some minor changes. There are numerous threads that cover this topic if you choose to go this route.
Oil
  • Oil is 15W40 for diesel. (HD 30W works very well in hot ares) Rotella is available in gallon jugs, and quarts at just about any convenience store or truck stop. Engine capacity is 7 quarts.
  • Oil filter is Stock Filter is AC PF-35; FRAM# PH5; WIX 51061; NAPA# FIL1061; K&N# HP-3002
  • Oil and filter change recommended every 3 months/3,000 miles
Coolant
  • Engine coolant is any standard ethylene glycol. The Lube Order indicates a 50/50 coolant/water mix for normal use; or 65/35 if temps are -10F or colder.
  • System capacity is listed as 25 qts.
  • Drain, flush and fill every 2 years, or 24,000 miles
  • Hockey Puck Thermostat - NAPA 381-190, Autozone 42995, Orielly 42995
  • Transmission fluid was indicated as Dexron II. This has been replaced with Dexron III.
  • Transmission filter is NAPA# ATP14558 (or 19701 w/gasket); FRAM# FT1020A (w/gasket)
  • It only takes 1 pt. to raise the level (hot) from “add” to “full”.
  • Capacity is listed as 4 qts., but this may vary. Fill as needed to reach level.
  • Drain/Fill and replace filter every 2 years. Do more frequently if regularly using off-road or for towing
  • Fluid is Dexron III
  • Capacity is listed as 5 qts.
  • Level should be approx. 1/4” below edge of filler plug hole
  • Drain and fill every 2 years/24,000 miles, or annually if under heavy use
  • Fluid is standard GO (Gear Oil, 90/75)
  • Front capacity is 4.5 pts.
  • Rear capacity is 5.4 pts.
  • Only the M1028 is listed as requiring additive. Additive is GM.
Brake Fluid
  • Fluid is DOT5 silicone only. CAUTION: Some of these vehicles may have been filled with DOT3. There are numerous arguments for using either kind. However, do NOT mix them.
  • Level should be ¼” below lowest edge of each filler opening in master cylinder
  • Check monthly
Power Steering
  • Fluid is standard power-steering fluid.
Air Cleaner/Filter
  • Any standard filter designated for use in a K5/K30 should work. FRAM# CA3492 (or PRA3492); NAPA# FIL2096 (or 6096); K&N# E-1690 (expensive, but worth it!)
Glow Plugs
  • Wellman 070 (about $10 ea.- search ebay or google it)
  • GP Relay is NAPA# ST85, Advance Auto #S603 (AA is much cheaper)
  • For 12V CONVERSION, Wellman 050 or AC 60G glowplugs
  • Control Card/Controller/Modulator is available from flmv.net
Rear Main Seal (2-piece neoprene)
  • NAPA# FPGBS40529
Tires
  • For the M1009 the stock tires are Goodyear Wrangler ATs 31x10.50-15
Belts ( all but M1010 )
  • Driver side alt- Gates# 25-7575; Dayco# 15580
  • Passenger side alt- Gates# 7483; Dayco# 15490
  • Power Steering- Gates# 7448; Dayco#15455
When installing Gatorbacks, I (LavaRok) choose the following three belts:
  • Driver side alt - 15585 ( 58 )
  • Power steering - 15461 ( 45.5 )
  • Passenger side alt - 15491 ( 48.5 )
However, the P side alt was tight. I'd try the 15495 ( 49 ) next time.
Batteries
  • Group 31 or 6TLs
  • Really any 800+ cca batteries will do
Starter relay
  • AC40 (stock) - For a more dependable starting system, update your starter system with the Doghead Relay upgrade. This replaces the subpar relay with a heavy duty relay. It will save your starter from burning up. NAPA# SME 7018601.
Injector Pump
  • The IP is a Stanadyne Roosa Master DB2
  • The estimated life is 100,000 miles. However, keep in mind that these vehicles are 20+ years old. The seals are almost certainly shot, or about to go.
  • If you are leaking fuel from the bell-housing cover, it is likely drain off from the IP through a hole in the rear of the engine compartment
  • The first seals to go are typically the o-rings on the throttle shaft. You may notice a dripping from the L-shaped arm attached to the spring on the driver side of the IP. Seals are only a couple bucks, but replacement is a 4-hour job at minimum, requiring the removal of the air-intake manifold, CDR valve, loosening the vacuum pump, and possibly removing the fuel injector lines and removing the IP.
  • Rebuilt pumps are usually in the $3-500 range (plus $300 core charge if you don’t give them your old IP core). Take-off pumps can be had for around $100, but will eventually encounter the same problems. Getting your IP rebuilt is probably the best thing you can do for the longevity of your vehicle.
  • The right toggle switch moves power to the service lights, horn, dash, etc. or to the blackout lights. Pull it out and flip it up or down.
  • The left switch turns on the blackout drive light. Flip it up or down; it will return to center position.
  • If your lights suddenly don’t work, check the toggle switch.
  • Then check the fuses.
  • If it’s neither of the above, you’ll probably have to trace circuits to track down a short somewhere.
· M1009
· The M1009 is a 1984 K5 Blazer with a 1 Ton J code 6.2L instead of the normal C code 6.2L diesel and a TH400 3 speed automatic instead of the TH700R4. These modifications were done at the miiltary's request to make all engine/transmission components the same between the 1008 and 1009 trucks.
****The front springs are 3 inch wide 56 inch long and the rear springs are 2 1/2 inch wide 52 inch long. . *****
TROUBLESHOOTING:
Glow Plugs
Tools Required
  • Multi-Meter / test-light
  • Glow Plug Socket
  • 3' piece of wire, with ends stripped
1. Remove a wire from a glow plug. Have a helper turn on the key, and check for voltage between the glow plug wire and ground.
o If voltage present, use a test light and hook the end to the tip of the glow plug while its still in the engine. With the other end of the test light, touch positive. If test light lights up the glow plug is good. Do this for each 8 glow plugs.
o If no voltage continue
2. Locate Glow Plug Relay on firewall to the left of the master Cylinder.
1. check for voltage on the Left large terminal.
§ If voltage present, have helper turn on key, do you hear a clunk from the relay?
§ If no, take your piece of wire, hold one end on a good ground, and touch the other end to the small terminal with the BLUE wire.
§ If you still dont hear the relay clunk, replace it.
§ If you do hear the clunk, your controller card is bad. Replace it, or install the 'manual glow plug' setup.
§ If voltage not present, check for voltage on the left side of the resistor bank (behind air cleaner on firewall)
§ If no voltage, check wire feeding resistors to ensure it is properly connected to the TOP busbar on the firewall
§ If voltage present, verify wire between resistor and relay. if wire is good, replace resistor, or do the 12v resistor bypass.
[hide] - [top] - [edit]Charging System
Dual 100 amp alternators wired in series to make the 24V. Very strong charging system that will handle any load you can toss at it. Changing over to 12V is NOT recommended.
The Passenger side Alternator MUST HAVE a isolated Ground. The Driver side does not. A Autozone Part number for the DRIVER side alternator is DL7157 (also found in a 1975 cady with a V8 engine) This Alternator is 78 AMP and works just fine. You MUST have a Isolated Ground Alternator for the passenger side. Ebay, www.saturnsurplus.com, and many other places stock this alternator.
NAPA has a remanufactured Isolated Ground Alternator. WIL 90014277. Wilson Alternator rebuilds them. Cost ~$220. Just make sure you test the alternator before you install it. They have had some issues with the rebuilds of NOT being isolated grounds.
27si Type 100 Series
[hide] - [top] - [edit]Starter
24V but can be changed to 12V.
To convert to 12v, move the wire that goes to the starter (big red one) off the junction block on the fire wall and moved to the + side of the first battery. This should be done only if a 24V replacement can not be found. With the 24V you have the power of both batteries, with the 12V only the first battery. Also, you need to remove the under dash starter relay and connect the Purple W/White tracer wire to the purple wire.
[hide] - [top] - [edit]Headlight Blackout System
12V sealed lights. On some you may be able to replace the black out drive light in the grill but all the bumper lights are sealed.
[hide] - [top] - [edit]Repair Guide
[hide] - [top] - [edit]Rear main seal replacement without removing engine
Autozone rear main ~ $22
Autozone oil pan seals ~ $12
Here are the steps I took:
1. Jack up front end frame, to raise frame slightly off axle. Even an inch will help.
2. Drain oil, remove filter.
3. Unplug batteries
4. Remove starter
5. Remove bottom access for bell housing, tricky since tranny cooling lines have to be pushed over a bit, no need to remove the lines though
6. Pull oil pan, may need to loosen a line for the front axle breather from frame rail, tends to block access to front bolts on oil pan. Use a screwdriver to gently pry the pan loose from the engine block if it sticks; which it should if RTV was used.
7. Remove oil pump/pickup
8. Remove rear main bearing cap
9. Remove old seal
10. Install new seal, carefully. I had a helper and with 4 hands we were able to hold it in place while applying pressure to push it in the grove. Take note of placement, mine was labeled which side points out. TM shows a shim which can be made to assist in seal install. I'd be wary though as you don't want to damage the seal.
11. Following the TM, use anaerobic sealing compound on the rear main cap as specified, install rear main cap and torque to spec.
12. Reinstall oil pump/pickup
13. Clean old gasket from oil pan and engine block. RTV oil pan gasket to oil pan, let sit for 10 minutes, RTV top of gasket, let sit a few minutes; then reinstall oil pan while trying not to get RTV places it should not be.
14. Reinstall bell housing access cover and air breather line for front axle if removed.
15. Reinstall starter
16. Install oil filter
17. Fill oil, check level, etc.
18. Reconnect batteries
19. Start it up, recheck oil level after idling for a few minutes and verifying no leaks.
That is about it! If anyone sees a step I missed, please edit this. As long as you have another vehicle to drive in case the job takes longer than you hoped; you'll be fine to try it yourself. It took me two days, maybe 7hrs total. First day, I setup doing steps 1-5. Once you pull the oil pan, you will want to finish through step 13.
GM REAR SEAT COVER TRIM CUCV BLAZER # 14075816
Credit goes to doghead for his instructions in thread "underdash starter relay" and the wiring picture as well.
This modification replaces the standard GM underdash starter relay, GM Part# 15591718 (which is prone to sticking), with a higher rated 200amp relay from Napa.
1. Buy Napa part# 7-01860-1 (SME line)
2. Disconnect your batteres
3. Remove diagnostic port under the dash and a couple screws which will release the mounting plate for which the relay is mounted to
4. Pull the mounting plate with relay down out of the dash so you can get to it, and remove the relay from the mount plate (IMG00541)
5. Mount the new Napa relay to the mounting plate. You can use one of the existing holes and then drill the other (IMG00542)
6. Cut off the old relay from the wiring as close as you can (IMG00543)
7. Put ring terminals on, and wire to the new relay according to doghead's picture (starterrelaywiring)
8. Tape everything up well with electrical tape so you don't have bare metal sticking out anywhere
9. Replace the mounting plate up into the dash, replace diagnostic port, and re-connect your batteries
10. Start truck with confidence
PAINT:
INTERIOR DASH ETC.
It's called 'Bronze Metallic'
The guy mixed me up a quart of
SEM
Color Coat
3254
85 GM
76D Bronze Met
militarymix
ottawa IL
Getting back to business... I have a solution for the infamous starter relay. I have found the contacts in the relay get "burned" and thus have a tendency to not make contact or arc burn together causing the connection to be unbreakable electrically. I removed the steel cover and cleaned the contacts using sandpaper or small file, then coating with electrical grease. Lastly replacing the cover.
salt6
B'ville, OK
Was at the parts store today getting parts for the M1009. Needed some info and was able to pull it up on my iphone. Showed it to the parts guy and figured out what I needed. So here is a good reason to have a INTERNET capable phone.
top_prop
Suffolk, VA
I just cut and pasted the summary posted by Mohawk Dave earlier into word and started working on it...
I further edited it, pasted a few pics in, and turned the language frequently from first person testimonials to checklist type procedures...
I'm a hobbiest, shade tree mechanic... Please PM me if if you find any errors, I'll fix them and repost it here.
I cannot claim credit for this file other than editing it, and I'm sorry that I'm not giving individual credit. If its a rub for any one PM me what parts you want credit for and I'll add your name to that section and repost here... I've put a lot of work into editing and formatting... removing duplicated data etc... I'll gladly add your handle if you ask!
I just want to make a good document to print and keep in the truck.
Yours,
Tom
(ETA: attached PDF updated 26 May 2011)
(ETA: added more pics including circuit diagram a few posts below)
(ETA: 31JUL... added fuse diagram from Terracoma's post below)
(ETA: 06 DEC... totally revamped... added multiple colorized electric schematics)
top_prop
Suffolk, VA
I tried to add the Fuse box diagram... but every time I did it came out bad... must be a transfer issue... if I can figure it out I'll do it!
top_prop
Suffolk, VA
I haven't tried to print your latest version... but... when I put that fuse box pic in it printed all dark and was barely legible... I think its due to it being a color JPG file... it really needs to be converted into a B&W GIF or PNG or BMP... then it will print well... hopefully what you put together doesn't print all dark and unusable like my previous attempts...
Thanks for your contribution!
Tom
ETA: I've updated my version of this in my post above... mohawk dave's is a bit older... I just added some more pics and stuff... judging by posts below it may have errors... keep the updates comming and I'll continue to update
Warthog
241
OKC, OK
Just for everyones infomation, the fusebox diagram that is copywrited by M1075 and just posted is not correct. And the the fusebox diagram in the Tech Manual is also wrong.
Warthog
241
OKC, OK
Hi Warthog,
Thanks for pointing that out. I copied the one from the TM and revised the sheet. This is correct one, right?
Thanks again,
Dave
The one from the Tech Manual is not correct. It is close but a couple of items are mislabled.
LeadHead
Hardy, VA
One thing I've learned from working on trucks and diagnosing problems is this: always used the KISS method. Keep It Simple, Stupid. Start with the small, easy things, and move on to the harder things.
Just a little tip. I have that problem to overthink things.
top_prop
Suffolk, VA
I'm looking for glow plugs for my truck now and am finding these (13g) available at autozone and summit. These are specific for the cucv no? Since they are obviously not obsolete are their any advantages to using the 60g?
The idea of this thread was for people to post succinct complete answers to questions like this... typically after they did a search for the info or posted their question and got a bunch of answers.
That said: Do a search... you'll find a ton of info the different glow plugs. The AC60G's are the ones recommended for good reasons. Also search and read about doing a 12V bypass to prevent a failure of the resister from melting your glow plugs. I even posted a hotlink to what I think is the best thread on GP's and bypassing above.
[I chose AC60g's after doing a search and reading the PDF I generated above. From what I gather: AC60g's cost more, but are considered the best due being self limiting and typically not swelling and being super difficult to remove. Others will fail and swell up and can be very difficult to remove (like removing the intake manifold to get the chunks out of the cylinder or even damaging valves/piston faces).]
Warthog
241
OKC, OK
Just incase anyone has, or will have the issue I had, My fuel cap gasket fell apart the other day fueling up. I didnt think that much about it till
I got home and realized I was leaving a trail of 3.70/gal diesel.... CRAP! So I started to look around at the parts stores... Never fun if you cant say you need a part for a 86 k30... But I found one that works, Its a thermostat gasket. Oreillys pn: MCS 2381
Thanks that1028guy.
Search for 2381, Product line MCS, Murray Caps and Stats. Price $3.29
May not be a perfect match but it does seem to do the job.
