- 6,158
- 8,647
- 113
- Papalote, TX
Any comments on the Federal dual locking door handles?
Somewhere lost in the back corner of my head I seem to remember a post or info on making your own...... just adding the key cylinder and arm maybe???Any comments on the Federal dual locking door handles?
I do not have the D punch to install the cylinder correctly, I also think it is doubtful anyone building these has the correct D punch but maybe I will be surprised, otherwise it is REAL easy to just stick a screwdriver into the lock and turn, it can also be done if the correct punch is used but takes allot more effort.Somewhere lost in the back corner of my head I seem to remember a post or info on making your own...... just adding the key cylinder and arm maybe???
I have a guess that might be right down your alley. Hope this helps.
Good things always happen when you buy double D’s
[/QUOTE
I have the same looking, without the twistie thing on the inside. I remember "South Co Manufacturing ??Typical of side box / tool boxes with pull up handle / lock set-ups. I think...Thinking again, they make most of them you see.
Many $$$$$ dollars cheaper that the ones being sold else were. Stainless or unpainted steel, sold direct from factory.
Problem...If you lock them and close the door or just lock them from outside >>> occupants CAN'T get out that door with the push bar on the X doors.
Not good.
Good part, slows down the boogie man a little, CAMO
