few fuel pump questions
GoHot229
Be careful with the ether. A little bit of ether goes a long way with a multi.
Here, here........He's right !!! on the same note, instead of either, you can pull the mushroom AIR CLEANER CAP ans pour a shot-glass worth of raw or two-stroke pre-mix your choice, anyway a shot of gasoline is SO much more LESS damaging and works as good as either, if not better.
cranetruck
94
Meadows of Dan, Virginia
Could be setting up for a runaway situation here, a combustible liquid in the air intake? The ether kit supplies a precisely metered amount of ether (gas) and is only to be used while cranking.
