file upload size
Guyfang
27,283
Burgkunstadt, Germany
Greetings!
I have a question, or two, and am not 100% sure here is the right place for it, but anyhow.
What is the max allowed size of an uploaded file, for the TM upload threads. I have a new manual that is 40+ KB and it runs through the upload function until it gets to 100%, and then just disappears. Am I doing something wrong, or is it to big?
Aren't the uploaded files in the TM upload section not supposed to be moved into the proper TM section?
Take care all!
Guy
5,184
The file upload size permission for PDF files are nearly 100mb, but the time to upload that large of a file likely would timeout for some users. So that's not the issue here. 40kb is not large at all. It is a PDF format right?
As to the upload section, that's just a staging area for files. I move them to the correct order. Probably need to go do that now....
Guyfang
27,283
Yes, its PDF. The strange thing is that it runs through the cycle, from 1 to 100 %. Then nothing. No message, no nothing. I will try again, but this time not look around for threads or anything else.
If you can think of anyother thing that might help, please let me know. There has been a lot of threads on the 2 KW gen set.
