Filter for derale performance 14202 TH400 deep pan with cooling tubes
firefox
General
51
Berkeley CA
Does anyone have one of these cooling pans for the TH400,
and if so, what filter are you using with it?
Thanks!
Bruce
biggestc69
Council Grove KS
I have one and the stock filter is what I am running. I dont have a part # for ya, but if you are buying it to use the spot on the side of the pan for a temp sending unit, which is what I wanted it for you wont be able to. The spot is right next to the front driveshaft.
firefox
General
51
Berkeley CA
Thanks guys!, Since the stock filter works, I am assuming that the
extension is not a seperate piece, but just by virtue of the tubes
built into the bottom, right?
I got mine from a fellow SS er, and the instalation manual was missing. Did you use the gasket dry, or did you use some kind of
gasket sealer on one side?
Bruce
ken
25
Houston Texas
I am using the stock filter. With no extension. I just keep it at the proper level on the dipstick. It has worked great for 4 years now. The extension is a tube the goes between the filter and the intake hole in the valve body.
1,808
Is that a dry well or just a boss to screw in the sensor?
firefox
General
51
Berkeley CA
Thanks Ken, That clears that up. I actually have the extension.
I just didn't realize what it was. Duh
Bruce
biggestc69
Council Grove KS
Its just a bung with a plug in it that you can screw in a temp sending unit. I bought mine for that reason and it sits about 3/8 of an in from the front driveshaft. Had to end up using the test port on the drivers side for my sending unit location.
firefox
General
51
Berkeley CA
There is a small threaded reinforced hole on the side of the pan
which I am assuming is for the sensor. comes with a small threaded plug for it.
Bruce
firefox
General
51
Berkeley CA
OOPS, didn't type fast enough.
Did you use gasket sealer on the large gasket or just smear with oil?
Bruce
