firefox
General
- 1,844
- 52
- 48
- Berkeley CA
Does anyone have one of these cooling pans for the TH400,
and if so, what filter are you using with it?
Thanks!
Bruce
Thanks!
Bruce
Is that a dry well or just a boss to screw in the sensor?I have one and the stock filter is what I am running. I dont have a part # for ya, but if you are buying it to use the spot on the side of the pan for a temp sending unit, which is what I wanted it for you wont be able to. The spot is right next to the front driveshaft.
Its just a bung with a plug in it that you can screw in a temp sending unit. I bought mine for that reason and it sits about 3/8 of an in from the front driveshaft. Had to end up using the test port on the drivers side for my sending unit location.Is that a dry well or just a boss to screw in the sensor?
