filter numbers
leroygreen
Mt. Vernon, IN
One eye, check out the bottom of this page in similar threads. I think the info you need is there.
Search and you will find hose and belt part numbers also.
1,176
Advanced search in the Deuce forum for "filter numbers" gets you 88 threads, surely one of them has correct filter numbers listed.
This one has the info you need and I found it in about 3 minutes. http://www.steelsoldiers.com/deuce/63544-oil-fuel-filter-numbers.html
Next time please spend a bit of time and effort and use the Search function before posting simple common receptive questions. It's expected, no complaints needed...
M35A2-AZ
390
Tonopah, AZ
I used wix filters.
Oil 51133 x2ea (wix gold)
Fuel 1st # 33511 (wix)
Fuel 2ed x2 #33512 (wix)
For napa # just take off the 1st number.
But the oil filters did not come with the right gasket, so you have the get a gasket #15070 x 2ea
The search on SS is a plan but it does work if you just take the time to look at all the threads.
Good luck!!!
jasonjc
289
Gravette Ar.
There are better choies for the fuel filters. I've posted the numbers befor but can't think of them off the top of my head. Even posted pic's of them.
