Catskinner
- 0
- 0
- La Luz, NM
OK= I've read most of the stuff here and have started my own filtering ventures.
Ordered 10 and 1 micron socks from Complete Filtration- while waitng for these to come in I cut the leg out of a pair of Wranglers and have filtered about 10 gal of Rotella 15/40. I mixed in 5 gal of diesel to thin it . Put this mix into a tank with hand pump which puts it thru a water trap filter from Tractor Supply. I "think" this is usable now- Any thoughts or comments?
After reading about the centrifuges- I am thinking of the OC20 model from Fryer to Fuel $153.00- Needs oil pumped into it at 60-100 psi. The kits I've seen with the 1/3 hp motor and pump are $800. or so- My idea here is to rig a 20 gal compressor tank with fill port and pressurize with shop air to deliver my mix to the centrifuge. I'm asking for comments here as this seems like a simple and cheap way to feed the fuge- but maybe I'm missing something here. Thanks
