- 2,582
- 2,272
- 113
- Efland, NC
Those RPMs are a good bit higher than spec. Full wide open with zero load should be about 312 hz on the mechanical governor (3750RPM). Full load RPM should be 288 hz (~3500RPM). Someone has been tinkering with your mechanical governor adjustment. Thats why the safety wire is on the bolt.
So.. Lets back up just a little and get your mechanical governor set correctly. With the black knob pushed all the way down and locked into place, and the governor in the pinned position, the bolt with the hole in it should be adjusted to get you to 312 hz.
IF the governor and the engine are running correctly when you apply 100% load (by the amp meter) you should drop down to about 288hz.
Can you set it up that way and see what you get?
