Finally bought a MEP-831a
DieselAddict
2,333
Efland, NC
I think you should. You'll need the lowest resistance path possible to get the most accurate compression reading.
AfghanVeteran2010
29
Odessa/Texas
This is the best I could come up with for connecting it to injector. Wonder what will happen to the connectors at pressure. Think this is a good idea or bad idea?
AfghanVeteran2010
29
Odessa/Texas
Going to seal threads with Teflon tape, and test. From what I've seen others do on YouTube with gas engines, that they crank engine till pressure peaks out at. Is this correct?
AfghanVeteran2010
29
Odessa/Texas
Cylinder compression pressure at 3000 rpm engine speed (turn the starter motor) Standard: 427psi Service Limit: 356psi. The air compressor fitting I use probably won't hold at that pressure. I was able to put something better together. As for low pressure side of injector I'll place a screw in it ill also attach a hose and bend it over.
AfghanVeteran2010
29
Odessa/Texas
Did the compression test best I could get is 150PSI. That not nearly close, I checked for leaks on fittings couldn't find any with soap and water. I did observe when I let off of the starter the pressure jumped a tad 20-60 PSI, don't know if this is normal. My brother said I should try applying pressure to cylinder, see its a valve leak. As for the fitting and tubing I got it from my dad, he work in oil field.
DieselAddict
2,333
Efland, NC
I think the very small diameter line is restricting the flow too much.
Doing a leakdown test is a good idea.
DieselAddict
2,333
Efland, NC
There is an orifice in the leakdown manifold that regulates the airflow into the cylinder. Normally you use about 90psi input.
DieselAddict
2,333
Efland, NC
Not in the cylinder. You'll have 2 gauges on the tester. One is the input pressure. You'll adjust the regulator on the leakdown tester to a value indicated on its leak rate table (input gauge). The second gauge is downstream of an orifice in the manifold that limits the volume of air that passes through. The difference between the gauges lets you know if you have problems in the engine. The more leakage in the cylinder the lower the pressure on the second gauge.
AfghanVeteran2010
29
Odessa/Texas
Is it normal for the exhaust rocker arm to move around like this(side to side)? The Intake rocker is solid as a rock(side to side movement), I have looked at engine TM and yanmar manual and could not find any remarks on this.
DieselAddict
2,333
Efland, NC
That doesn't look right to me. Is there any odd wear pattern to suggest that its been moving out of position over the valve?
