robson1015
- 134
- 43
- New Concord, Ohio
Guyfang - I have an assortment pack of o-rings but don't know if they are diesel fuel compatable.
I am in the midst of building a load bank that will go up to 13.5kw for this very reason.. the 803A currently under my watch has the thermostat pegged at 180 and unmoving (but it did move when I first got the machine). My hookup on my house is only 30A, so I cant even draw enough to make this thing sweat. I am adopting most of this design, with some changes to work for me: https://www.steelsoldiers.com/showthread.php?163190-Homemade-Load-BankRan it for about an hour and a half. Looking for an apartment size electric stove/oven for a load bank. Will run it under load soon when I find load bank. So far very happy with this unit. More later.
If you are bored, the manufacturer of the part (According to the NSN is B.W. ELLIOTT MANUFACTURING CO., LLC). The manufacturer part number is 347L-032-2. I show BW has a dealer in Ohio... wouldn't hurt to call them to see if they can source it for you?Update - just got an e-mail from Armyparts.com, they gave me a full refund and stated that they can't fulfill the order - ???
I just did the quad fuse modification on mine, where do I get the scoop on the MOV mod?Hardware cloth is a good idea. Looks like your missing the MOV install on the modification.
Aha, found it!I just did the quad fuse modification on mine, where do I get the scoop on the MOV mod?
-- Carl
You should use some of this same cloth material to cover up the drain holes in the underside of the machine (like under the battery trays).View attachment 696348View attachment 696349 Hardware cloth...
Did that - just need to do the middle opening under the engine after I lift the unit up.You should use some of this same cloth material to cover up the drain holes in the underside of the machine (like under the battery trays).
B.W. Elliott price= $250.00 -still lookingIf you are bored, the manufacturer of the part (According to the NSN is B.W. ELLIOTT MANUFACTURING CO., LLC). The manufacturer part number is 347L-032-2. I show BW has a dealer in Ohio... wouldn't hurt to call them to see if they can source it for you?
Ohio Pipe Valves & Fittings4000 Trent AvenueCleveland OH 44109
Phone: 216-631-6200Email: mresch@valvepros.com
