halftrack
- 10
- 38
- New Orleans, LA
Well, finally got around to installing the M66 ring mount on the truck. After a thorough break down and lube job on the ring, I managed to get the ring installed. THAT SUCKER IS HEAVY! At first I thought me and a few buddies could just lift it up and install it. NO WAY. So, I had to get a big boy with some reach and muscle. I don't know if the way I have it installed is right, but the bolt holes matched perfect for the way I have it. If it is wrong, it is staying wrong. However, I am open to criticism and suggestions. By the way, you will definitely will need the support bracket that goes in the back of the cab wall. I currently do not have one but will install one later. Also, I decided installing the ring in a open area was not challenging enough, so I installed it in a confined area (my backyard) with power lines hanging around.
Sermis, do you have any more rings?
