Finding Drill Bits
814
Universal City, TX
I am having a problem locating larger drill bits that will work on frames and the metal on a trailer I am modifying. SO far I need a 9/16 and there is a larger one as well that I don't have a size for. Anybody have a place that they get larger drill bits from that work well for metals?
Thanks, Mik
391
Atlantic, IA
I can recommend these, as they worked fine for my purposes (metal lathe) and inexpensive.
http://www.grizzly.com/products/Sil...993?utm_campaign=zPage&utm_source=grizzly.com
These work well too, if you are drill through the thinner stuff, but I got mine through Harbor Freight. Again, fine for my purposes, but then I am not in the business of making money with my tools, well at least not my drill bits.
http://www.grizzly.com/products/Step-Drill-2-pc-Set/H8197?utm_campaign=zPage&utm_source=grizzly.com
Jbulach
2,056
Sunman Indiana
Silver and Deming set from Harbor Freight (around $35) holding up well for me, however I have always be fairly good at resharpening them when they dull or chip the corners. I have been eyeing those step bits as well recently, but have no experience with them.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Same here. I use them primarily in my mag drill, but have used them in the old gear reduced hand drill. Don't let them "catch" or your wrists will hurt for a week.
Jbulach
2,056
Sunman Indiana
Well now if you have a mag drill, annular cutters are well worth the money. If you don't have a mag drill and have a bunch of frame holes to drill you might want to look into renting one.
gimpyrobb
27,785
747
Cincy Ohio
Mine is an ancient B&D with a chuck, I have yet to get the adapter for annular cutters, but do have 2. I just need another metal project, and I will most likely upgrade at that point. Then again, twist bits have worked fine for the last 4yrs.
TsgtB
Granbury, Tx
The step bit works well, as it starts small, and you feel it move to the next bigger step on the bit.
Mine has never dulled, but you must take care not to just "ram it home" or you'll end up with a 1/2" hole, when you only wanted 3/8"...
Drill a bit, catch your breath, see if the bolt will fit, repeat as required.
DeucesWild11
12
Putnam County, NY
Step bits work for me too! I got a few from Harbor Freight and they last pretty well, only broke one or two, but for the price at HF who cares.
I pretty much only use them on metal when I need to drill out something.
gimpyrobb
27,785
747
Cincy Ohio
Depends on how thick the metal is. If your not drilling sheet metal, the step bit is useless, imho of course.
DeucesWild11
12
Putnam County, NY
You got to use sharp ones Gimpy! lol, It's a little harder yes but it works, just got to use the right type as there are a lot of different combinations/styles of them
gimpyrobb
27,785
747
Cincy Ohio
I have sharp ones, but if you use them on thick metal you end up with a funnel type hole, not a hole with square sides!
rosco
27
Delta Junction, Alaska
Don't turn the larger bits too fast - that's probably as slow as you can go. Always use a pilot hole. For 9/16", my pilot would be no larger then then 3/16. Its easier to locate & the larger bit will follow it. The whole process will be a lot easier, using a pilot hole. Cutting oil is best -it's designed to remove heat, without lubricating. The small can will last forever. If your going to use drills (any of them), you need to learn how to sharpen them! It only takes a small grinder (of course - the bigger, the better). Do it by eye. Jigs are too slow. Study a good bit - how its ground, then grind yours. If you don't get it right, try again.
TsgtB
Granbury, Tx
I marked my bolt locations, center punched them, the smallest bit on the tip of the step bit is roughly 3/16".
There is flat space for a almost 1/4" before the next larger step starts to cut.
At full diameter, I may have started to cut 1/16th or less into the metal, not the full width of the next larger step, at full depth.
I used the longer/skinnier bit with more space between steps. (The short fat ones would make "V")
IMO it was equal and easier than changing bits to next larger size.
A good ol' plug in drill, with some nads, and not a battery drill.
Did not use cutting oil, bit did not get very hot.
infidel got me
32
Newberry, Florida
My local napa store sells what I call bodymans bits. They are 1/8 inch double headed bits, meaning the can be flipped in chuck when one end breaks or dulls. They are used to drill out spot welds on body panels. These are cheap and plenty sharp. I had good luck with these to start pilot holes.
Isawfrizzy
St. Paul, mn
Like rosco said, slow and cutting oil. Speed kills.
Jbulach
2,056
Sunman Indiana
Uggg... but, I guess beats the old hand drill any day!
I have plenty of metal projects for you, and I'll even let you use my drill!
What speed does your old drill run? Mines a single speed 550RPM and is really pushing it with cutters over 1-1/4", you have to pour the cutting fluid to it.
gimpyrobb
27,785
747
Cincy Ohio
Mine is in that neighborhood, but luckily the magnet is powered independent from the drill. I can hook up a router speed control and lower it all I want.
