Fire.....well amost
sermis
17
Temple, TX
The brake system is fried, no really fried. My son was pulling back into the house and the brakes were kinda "squishie".
He parked the truck and opened the hood and then saw sparks coming from the area of the master cylinder and then the brake lines got red hot. The front brake line from master to caliper melted into. He said one of the rear brake lines is now dripping too. I'm guessing it got voltage into the brake system but from where?
infidel got me
32
Newberry, Florida
Ground takes path of least resistance. It will fry your clutch cable on a vw gti if electrics are not grounded properly. Ask me how I know.... Or a hot wire hit a brake line/master cylinder.
Wire Fox
161
Indianapolis, Indiana
Exciting! ...in a really awful way.
I can't really answer exactly where it happened, but it seems clear to me that a positive wire short-circuited to your hydraulic brake line. The brake line can easily contact chassis ground and it's likely its normal condition, so as soon as one of the positive cables somewhere contacted the line, it would have completed the circuit and formed a short circuit. This diagram out of the TM should be able to help you start you diagnostics, since it shows where the metal hard lines run and may make it easier to trace the brake line and find that short.
Just based on where you saw all the sparks and excitment, I almost wonder if your alternator failed and started producing a voltage high enough to create an arc? I really don't know how probable that could be for it to produce a high enough voltage to arc that size of air gap. Did the sparking stop when you stopped the engine or when you pulled the battery?
Wire Fox
161
...or this. I didn't think about it, but also check the grounds going from the engine and alternator to the main body harness/battery box. If those failed, it could have flowed energy from the engine bay through your brake lines. You're seeing first-hand why electrical diagnostics can be tough.
TOBASH
3,475
Brooklyn, NY
First check all engine ground cables. then check alternator ground wires. Finally check starter wires and stuff. Also check wires to batteries! They are old and if they short circuit they are attached to body and brake lines.
Only a few things have that kid of juice and are not on a fuse.
If this does not look simple then it will be faster and cheaper to buy an entire new wiring harness.
I feel bad for you and your son. Still, blame it on him and make him do all the family chores. (Silver lining)- just kidding.
IMHO
T
sermis
17
Temple, TX
And yes my Son was thinking and pulled the battery cable and started putting water on on the red hot lines to cool it off.
I'm sure it was exciting to see,. When I got home he was still excited....LOL
juanprado
2,916
Metairie/La (N'awlins)
Just a thought but how about the Cadillac valve or the time delay relay for the fan as both are close by? I know my time delay was all soft and gooey with epoxy running out. I have heard this can be an issue for fires/shorts?
1,178
Calipers should have been isolated by the rubber hoses.
1,178
Do they have a starter motor, end support bracket ?
sermis
17
Temple, TX
Yes. I'm guessing the starter bolts snapped off then the entire starter turned and shorted out
Sent from my SM-G920V using Tapatalk
1,178
So, they do, or do not , use a motor end support(like a cucv) as well as the 2 long bolts?
Wire Fox
161
HMMWVs do have a tail-mounted support bracket on the starter. Two versions, in fact. One is a straight slot and the newer version is more of a J-hook to help support the alternator while you install it. Sermis, did you have this rear bracket installed?
1,178
Vibration/harmonics, definitely could have been the issue, without the additional bracket.
