- 499
- 29
- 28
- Kingman AZ
It cranks--- GREAT!Well.... Then i pulled the fuel inlet hose to the filter and cranked the engine, bone dry. I know there is fuel in the tank, i dumped 5 gallons in myself and the gauge is showing 3/4. I assume this means my lift pump is either not receiving fuel, or bad.
Question; Did you remove the fuel cap first before cranking? It's all there in the TM's!
If you did then BINGO-- your fuel-starved for some reason or another. Now before you go buying a new fuel pump, take your fuel line loose at the FP under the rt-side engine block and see what's what... try siphoning. Still no fuel? Maybe there's a kinked fuel line to go with yer' bent drive shaft! (bad joke)
Anyway, a thourogh inspection of the fuel delivery system would be my next move... GUH-LUCK!
