First Deuce is home
18operator
1,861
Seville, Ohio
Congrats on the nice looking truck! Take your time and get to know it very well, especially the brakes. I too had to make an emergency stop the day I picked mine up. It stopped fine, but when I took the front drums off I found 2 leaking wheel cylinders.
779
20
Springfield AR
You can eliminate the Jay pipe if you choose to. I'd put a flapper on it so water don't rust it out again or freeze into ice and you can't start it. I'd flush the brake system out and check for leaks as well. The brake fluid you may or may not have is DOT5.
Hometown
Denton, Md
I have read about the Dot 5 fluid. Ill definitly be researching fluids this week as Ive learned they just stood her up and wiped her nose and sent her out the door, which is perfectly fine, I just need to establish a baseline and get everything freshened up.
