First deuce--need help.
dirtyfingernails
Gainesville, FL
I test drove a 1971 am general with LDS-465-C and air shift this morning. The rear hubs had been flipped, so it only had single tires (900s). It started right up, cold, stopped very sharply and didn't seem to burn any oil-no obvious blue smoke (although there was a little on start up). A few drips here and there, but it seemed pretty tight to me. I drove it about 15 miles down a country road maintaining about 2000 rpm. It held about 30 lbs of oil pressure throughout the drive. The body is several colors, green, sand. It was a forestry truck in MS. It is titled too. Asking price is $3200. I fell in love. Wife even okayed it for the driveway. I'm an extreme novice with this truck. It sounded like the air pump on the drivers side had a bad bearing, but I'm not sure--just a little tweek randomly. No real rust--minor stuff in my opinion. What else should I check out? Is this an okay price? I really need to know what to look for. I stood on the brakes about 5 times and there doesn't appear to be any leakage inside the wheels. Any advice or opinions would be greatly appreciated!
Steve
WillWagner
3,181
Monrovia, Ca.
$3200.00 Doesn't seem bad. Does it have a winch? Soft or hard top? Air shift, title..that's half the battle now..good brakes. Only the noise would bother me. See if they'll let you have a mechanic look at it, or maybe see if someone from here could go with you to look at it again. Sounds reasonable.
1,164
Brakes are reasonaly inexpensive and easy to do, but 30 lbs of oil pressure going down the road seems a bit low to me.................
1,827
I've had trucks that had 30 going down the road and lasted long time! Powerplant engineers rule of thumb, 10 psi per 1000 RPM. The intermittent compressor noise might be regular operating noise and you're just noticing it when its compressing.
dirtyfingernails
Gainesville, FL
No pictures and no winch. I was concerned about the oil pressure at 30. I suppose it could have even been the gauge. So, sound reasonable to you guys or should I keep looking? I know I'm asking a lot when you haven't seen it. What should the oil pressure be? The guy had plenty of dueces and said if something went out he'd replace it. Was a very nice fellow in Live Oak Florida. Thanks again.
DFN
jwaller
19
Columbia, SC
doesnt sound too bad. maybe a few hundered more than I'd pay but if it is close and you dont have to drive 1000 miles to get it. thats worth something. and he will fix anything that breaks, thats priceless.
citizensoldier
19
Northern Michigan. Smelt City
sounds good
How do the axle seals look? Are they leaking all over? What about tire condition? Did you put it through its paces? 6 low all gears,check all fluids,ingage the front,drain air tanks,check brake fluid,and on and on and on
I am new to the deuce scene also but that oil pressure seems low compared to my truck. But from what I hear they are hard to kill and it could go a long time with no problems.
Price seem ok but hard to say without seeing it.
1,193
RE: sounds good
LDS motor is a nice benefit. I would accept the oil pressure running low as long as it has some at idle warm(5-10psi). Not a bad price, I have about that into mine . If you can afford it I would say go for it, you will really enjoy owning driving and maintaining one. Good luck!
1,827
RE: sounds good
Live Oak eh? Sounds like that might be Matt. If I can get my ducks in a row, I'll be up there next weekend getting my cab for the M108.
texas-5-ton
10
Grandview, TX
RE: sounds good
Steve,
I used to own a 71 exactly like you are talking about and that was the best vehicle I ever owned. Seemed like it was even more dependable than my modern day transportation. That truck never let me down. Wish I still had it.
Chad
